Posts posted by lonil
The check engine light does flash, and I have check the engine codes (in haynes book) to see what it means, it flashes a 55 - cant find anything in the haynes book that relates to 55.
I'm going to say that shop is wrong or looking to make money. Subaru's have VERY tough valves, and you have low mileage. There is almost no way you could have bad valves.Your problem is most likely something to do with the fuel injection - idle air control, mass air sensor, or throttle position sensor come to mind, or some other sensor causing a rough idle.
GD
1992 Subaru Loyale
130,000 miles
Hey all, I had the local shop check out my subaru to find out what is making the idle so rough at low RPM's (motor shakes).. They ran a computer check on the car and what they told me was that one of the valves did not have enough compression behind it. I asked them what my options were and they told me new motor, or just drive it till it dies (they said it could last me 2-3 years)
Ok, I have never went this far in depth with a car, so this is ALL new territory for me.. I started talking to others around work and was told that I could get a valve job done on it to correct the problem. I was wanting to throw the valve job question out to the USMB community and get some ideas on price or anything I can do to make the process cheaper (and if its even worth the money) So far I have about $1,300 dollars in the car total ...
BTW - I have replaced the wireset, vacuum lines, plugs, cap, rotor, O2, and fuel filter in hopes that the vibration would go away - no such luck, so I took it to the shop.
Thanks for input!
Hey everyone, anyone know what size the stock front speaker (no rear speakers) is on a 1992 Loyale ? I measure the speaker guard, and it measures around 4 1/2 inches.. So I assume the speaker would be a 5" speaker... thanks in advance!
Edit: Thanks all for the replys, From doing some reading on the forums here, I believe a 6.5" would fit just fine, which makes me happy
No clicking on the steering wheel or the brake pedal yet, Even though my brakes are squealing sometimes when I stop, But as far as I know, thats just new brake pads .. Will inspect the boots ASAP! Thanks for the post!
Thanks for adding Gary !
Thanks Hank for the input - Couple people I have talked with locally have pointed me in that direction - New territory for me, but always willing to learn!
New to the forum /waves
I just picked up a 1992 Loyale for $800 dollars (129,000 miles/MT)here in Oklahoma, and enjoying the "new" car! Searched google and was so glad to see a message board dedicated to the Subaru'ist, Lots of good reading.
Searched the forums for Clicking on the forums for some reading, the question
I have is:
When I am at a complete stop (1st gear), and I start to take off and make a turn, I hear a clicking/popping noise coming from the front of the car.. after the turn is complete, the sounds seems to go away .. Any info would be
appreciated!
Valve Job 1992 Loyale
Posted
Gonna check on that ASAP, I cant believe I missed that code in the haynes book .. I cant wait to get off work and get going on this - I like my subby and dont want it to die :-)
Thanks everyone - will post results once I get done with it all.
