Levysoobie
  1. ok i have bought one and i don't know where the vacuum hose should go ,,, i put it on the turbo wastegate hose and no effect where should it go.???
  2. What would be the risks and would it work becouse i've heard that the turbo's output is just 7-8 psi , will it make that swosshhing sound and will it influence the engines running ???????
  3. i've got a MAF that is with the little wire's in them and it does'nt work could i put a vane insted of the original ? will it work?
  4. Hy i just rebuilt my ea82t engine and it runs very poorly when the engine is cold and the simtoms are when you accelerate it , it like dies and you let go of the throttle and it idles perfectly . after the engine warms up to temp it runs like a charm ,, could it be some vacuum connections or what ?
  5. Hy i've got a subaru ea82 turbo and i hate that clonking noise from the tappets any hints or something ???
  6. http://pdftown.com/Subaru-EA-82-Service-Manual.html here's a little help about the car good luck and god speed
  7. http://pdftown.com/Subaru-EA-82-Service-Manual.html Diagrams , pictures , everything in Detail
  8. my STOP LAMP indicator on my dash is running non stop when i put the ignition on it lights on and when i start the engine it still lights ,,,what does that indicate and what can i do to solve the problem ..help me pleasssseeeee
  9. i am from romania and i would like to know if you can send a air flow variator
  10. what happens with your ea82 turbo 4x4 if you take off you're air variator cable becouse if i put the cable on it runs worst than when it was off . i accelerate the engine but it won't go over 3000rev's and if i push the pedal quiqly it dies and it has'nt any power . what can i do?
  11. i would like to know what is the problem of my car. it does'nt have any power and when i push the acceleration it dies . also can the air flow variator be the problem becouse if i take the cable of nothing it still runs the same bad way. so can the airflow variator be the only problem?: what should i also check? confused: im desprate please help me. thanks my car is an 87' ea82 turbo 4x4
  12. i would like to know what is the problem of my car. it does'nt have any power and when i push the acceleration it dies . also can the air flow variator be the problem becouse if i take the cable of nothing it still runs the same bad way. so can the airflow variator be the only problem?: what should i also check? confused: im desprate please help me. thanks my car is an 87' ea82 turbo 4x4
