Leggm
  1. I own a 1988 Subaru GL with stock wheels, & I am wondering if the wheels from a 1992 Legacy match up with the bolt pattern of my 88GL?
  2. I replaced the timingbelts on an '88 GL w/1800 overhead cam. I set the marks to noon on the cams and lined up the marks on the flywheel. Placed the belts on and triple checked the marks. We have the rotor pointing to #1 plug wire @ 8° (posted on vehicle) & 20° (found in Chilton's) BTDC and cannot get the engine to fire. I have tried adjusting the distributor and even turned it 1 tooth in both directions but am unable to get it right. Any thoughts? I did a compression check (w/Full throttle) on the engine the results are as follows : 1: 148 2: 150 3: 162 4: 152 Are these ok? Mind you, this motor has 262,000 mls. Any insight or information as to what I may have missed or what to try would be greatly welcomed and appreciated. Thanks, Mike
