Everything posted by Gardensnake
'88 Justy not firing
Bump? Does that mean try to start it? William
First thought was water droplets. They weren't soaking wet or anything just little beads of water on them. William
How do I do a compression check if the car won't start. Wouldn't it start if the head gasket is blown? William
Okay, Tried changing the plugs just because I really didn't think it would hurt anything and was really needed anyway. While changing the plugs noticed a new symptom. There was moisture on the plugs. Any ideas with this new info,? Head or head gasket gone? Thanks, William
Haven't noticed any spark. It's just cranking like it's out of gas. Could the spark plugs be to blame? William
Just replaced the water pump on an '88 Justy and now that I've gotten everything back together, I can't get it to start. It hasn't been started in about 3 weeks and overheated rather badly before it was parked for repairs. Any one have any idea why it won't fire? Thanks, William :-\
'88 Justy water pump advice
Still looking for any advice I can get on this. Anyone? William
Okay, Another question connected to changing the water pump on a '88 Justy. Does the oil pan really have to be removed to change the water pump? Anyone here changed one before? Any hints? Thanks, William
Need help removing crankshaft pulley
Am attempting to put a new water pump on an '88 Justy and have hit a snag. I need to remove the crankshaft pulley but can't get it off. I've gotten the bolt out but the pulley still won't come off. It wiggles a bit but won't budge otherwise. I've been told there is a key way that has to be lined up but can't figure out which way the pulley is to be aligned. Can anyone give me anymore info? Thanks, William :-\
