Everything posted by corsair
Speedometer sensor location
corsair replied to rumlow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can't believe that you received two dead (new) speedos. The speedo that I ordered had two parts that come together: 1. the speedo face & 2. the circuit board that is connected to the back of the speedo face. Assuming that you didn't separate those items and use the old circuit board, I would have to guess that the next thing to check would be the sensor input for the speedo. I had the Subaru stealership take my car on a test drive with his diagnostic scanner who told me that he was able to see sensor inputs going to the speedo, so I bought the speedo head which cured the problem. I don't know how to advise you to determine whether you are getting sensor input pulses without having the stealership do it for you (because I don't own a factory service manual). Maybe you need to take your new speedo AND old speedo to a different speedo shop.
corsair replied to rumlow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's probably a 99% probability that the sending unit works just fine. I had the dealer do the diagnostic for me & he drove the car around on a test drive with his diagnostic equipment, noted that the speedo did not work, but that the sending unit on the trans was sending out a signal. I can tell you specifically that the circuit board on the back of the speedo gets ONLY ONE single input wire from the sending unit because there is only a single wire coming up to the back of the speedo head. This tells me that if you can remove the cable from the sending unit, attach a wire with the appropriate connector, and run it into the inside of the car to an analog meter, you should see input pulses when you drive. Since the car is too new to have the dealer factory service manuals circulating freely, there no other way that I can know what type of signal is being sent from the sending unit unless you can engage a dealer mechanic to tell you a better way to diagnose it. Alrernatively, you might trace the sending unit wire color back thru the harness to try to get a better place to tap into the signal coming from the sending unit (which is located on the left side of the trans with a single wire coming from it). I know it's galling to say, but you might just save yourself the trouble and just buy the speedo and install it. Mine was installed with ONLY a short & medium #1 or #2 phillips screwdriver and 45 minutes of my time. It will take you way more than 45 minutes of diagnostic time & effort trying to continue to isolate it. IMHO... Just replace it.
corsair replied to rumlow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX=================================================== Problem solved. I replaced the speedo head for my 1999 Subaru Legacy sedan w/auto trans (Subaru part # 85020AC330) for $160 (over the couter from the dealer). Now my intermittent speedo problem is gone. All it takes is 45 minutes and a medium & short regular phillips screwdriver to complete this R & R. Note that the part number above really includes 2 pieces, the mechanical portion of the speedo (including the dial & pointer) and the integrated circuit board mounted on the back of the speedo connected by 8 free-standing electrical connector pins & 5 phillips screws. Since the part from the dealer includes both items, I will never know whether the trouble was caused (only) by the circuit board. The circuit board has ONLY a single wire input (green wire with yellow stripes) coming from the sensor on the transmission. For those who follow, it may be worth investigating whether this circuit board is sold separately (and at much less cost) from the mechanical portion of the speedo/trip odomoter. If anyone wants pictures, please post here with a good email address & I will email.
corsair replied to rumlow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you very much !
corsair replied to rumlow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope, I didn't get any PDF or other diagrams, so I'm still in the dark about this. There are really only two possibilities though, the VSS sensor which sends the impulses, or the speedo element in the instrument cluster which receives the impulses. The only way to know, is the check if the impulses are being reliably transmitted, and if so, the only thing left is the speedo component in the cluster which receives the impulses. This is probably the same troubleshooting logic that the stealership will use if you are willling to pay to have the dealer do it. I'm not motivated to find out which one it is before I reach 100k since I have an extended warranty. I'll post the answer here in the next year (or so) when my warranty is ready to run out.
99 Legacy front axle nut socket size ?
corsair replied to corsair's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK. I pounded on it from the inside-out with a rubber mallet (did it this morning, but it didn't budge even a little). That's why I had thought of the axle nut. I guess I'll just have to use a bigger steel hammer and go all the way around. Thanks for the replies.
I need to re-face one of the front rotors on my 1999 Legacy L sedan 2.2. It appears that the front axle nut has to be removed in order to take off the rotor (I have not yet done this on my car). I don't have a big enough socket, so I will have to buy one. I measured the nut and it looks like either a 32 or 33 mm. socket. Can someone tell me what is the correct size of the socket that I will have to buy ?
Brake bleeder (stainless steel) where to get ?
Anyone know where I can get stainless steel brake bleeder screws (in the USA) for my 1999 Legacy L sedan ???
99 Outback Engine problems - Failed rod bearings?
corsair replied to Deadeye's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the engine doesn't turn-over with the starter, then the next step is to put the correct socket on a breaker bar and put it on the crankshaft bolt and see how much resistance you receive when trying to move the crankshaft with the breaker bar. If the bearing(s) are truly seized, you won't be able to turn the engine with a breaker bar !!
Phase I/II how to tell difference ?
corsair replied to corsair's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK..... Thank you. Now I feel fulfilled. I opened the hood, looked under the alternator and there it is "EJ22" stamped on the block. Hooray!! Now I won't have to feel left in the dark when I read threads where everyone is identifying their engine with the term EJxx. Now - when I look down to the post by Setright posted yesterday, combined with the Subaru Tech manual that I got from ferret, I understand what he is saying. Thanks to everyone who posted to this thread in the last 3 days. I have learned alot more about the boxer engine than I knew a week ago !!!!
corsair replied to corsair's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf that is the defining characteristic, then I definitely have a Phase II. I had a thread a couple of weeks ago about oil in the spark plug wells (to which you also replied) and which happen to go through the valve covers. The part as defined by Subaru is a the "Spark Plug Pipe Gasket". I happen to need all 4 of them. By way of verification that I own a Phase II 2.2, I also got a PDF yesterday from ferret which details the difference between Phase I/II. Shown in those pictures are the two different cam belt tensioners for Phase I & II. The one that I have is more round than long (the best way that I can describe it) which verifies that I own a Phase II 2.2 (I have already done the timing belt so I know exactly which tensioner I have). The problem that I'm having in this thread is the EJ engine designation that I keep hearing. Since I'm a Subie newbie I don't know where to find this number on my car or if it's even written on my car. I have a 1999 Legacy L sedan 4dr. 2.2 Phase II engine manufactured 11/98. This is the 1st boxer engine that I have ever owned. Everything else that I own is domestic (Corvette, Chevelle, Crown Vic. and F350). Am I supposed to be able to find this EJ number somewhere on the car and if so where??
corsair replied to corsair's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMany thanks ferret, this technicians reference will be very handy to me in the future. I now have a good reason to know that my engine is a Phase II, and it will be verified once I see what is under the valve cover.
corsair replied to corsair's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe manufacture date on mine is 11/98. The sticker under the hood (I never LOOKED at it before) says engine family XFJXV02 2.2. litre SFI and a long number for the "evaporative family" XFJXR01251BB. I have the Subaru FSM Supplement and it shows the air filter location for all 2.2 non-California cars as being on the right front fender with the intake opening behind the right headlight. All California cars are shown in the manual as having the airfilter mounted on the throttlebody inside the big housing at the center next to the firewall. Since my manufacture date is 11/98 (a Wisconsin Legacy non-Outback), I have to guess that I have Phase I as everything that I have read suggests that Phase II came in late 1999 and early 2000. My whole reason for wanting to know Phase I/II was an attempt to find out whether I was affected by the head gasket problem. When the dealer tells me that I'm not, I naturally believe that they are lying in order to get out of fixing something. Everything that I have read suggests that this problem was ONLY on 2.5 engines when Subaru took a 2.2 block and bored it out for bigger sleeves to make it a 2.5 engine (and adding the DOHC heads & valvetrain) [bad engineering decision]. If your car states compliance with California emissions (even if sold in Oregon), then I have to believe that you have a California car - this would put the air cleaner in the center housing right next to the throttle body. The right side intake box on a California car is "empty". Can you tell me what has been fixed on your car (and how many miles on your car)? I'm trying to get a picture of what will go wrong next on my car which shows 86,000+. I have already done the crankshaft seal & timing belt. I skipped the cam seals because when I had it all apart, I didn't have a cam sprocket wrench (or service manual) and didn't have time to fabricate one and weld on a handle. Sadly, I also didn't replace the water pump when I had it all apart. So what has been replaced on your car ?
corsair replied to corsair's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have basically the same but with an automatic: 1999 Legacy L sedan 2.2 30th anniversary Ed. 4dr. winestone pearl. The only major service that I have had is a leak in the auto transmission where the electrical plug goes into the trans and I was 2,000 miles out-of-warranty. The other major problem with my car is the intermittent speedo (not yet fixed). I have also had the driver seat recliner adjuster assembly go bad - seat bouncing up and down when the recliner adjusting arm is in center travel - not in fully locked position. Another minor problem is defective spark plug pipe gaskets which causes oil to puddle in the spark plug holes. Can you tell me what major/minor problems you have had with your car, so that I can know what to watch for in mine ?
corsair replied to corsair's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm a newbie so I don't know what "EJ25" means, although I have seen a similar reference in other (older) posts which I have researched. I CAN tell the difference between a DOHC vs. SOHC (I'm a mechanic & have a Corvette & Chevelle), but I read in some previous posts that a Phase I was a 2.2, and a Phase II was a 2.2 bored-out (at the factory) to make it a 2.5. The Subaru that I own is the 1st non-domestic car with a horizontally opposed engine that I have ever owned. If the defining feature is the air cleaner location, then I can tell you that my air cleaner is on the passenger side with an empty chamber behind the throttle body. However, I have a Subaru FSM (Supplement) which shows the (1999) 2.2 air cleaner location as ALL being on the passenger side, with the ONLY exception being the California car which has the air cleaner mounted in the chamber attached at the throttle body. There is no mention in this Subaru manual about PhaseI/II. The reason for my question originally is that I called Subaru about the head gasket issue, and they told me that I have a phase II engine and don't qualify for any extended service (the anti-freeze additive). This causes me to want to know definitively (and by objective criteria) as to whether I have a Phase I or a Phase II engine because the Subaru phone service rep on the phone could NOT tell me what is meant by Phase I or Phase II (obviously she is a low paid hourly employee who just runs a VIN # and tries to brush-off any many people as she can). I guess I'll just go and pay for the coolant additive myself and hope for the best. I have 86,000+ on my 99 Legacy, and don't have any leaks, but I might as well have the coolant additive, than not have it. If someone can give me a more specific, or technical way to distinguish by sight how I can know whether my 1999 Legacy L sedan 2.2 is a Phase I or a Phase II, I should like very much to hear it. If LOGIC would dictate, there would be a reason (different manufacturing process, engineering improvements/advancements, a different or more advanced engine design) that would logically dictate why Subaru would designate an engine being a Phase II, rather than a Phase I. On this (logical) basis, I would of course assume that it would be more desirable to have a Phase II rather than a Phase I engine, and I'm saying this on the basis of logical progression of improvements, not simply because the Phase I has the bad head gaskets.
Is there a way to identify a Phase I versus a Phase II engine when you open the hood and look at it? If I was looking at a used Subie how would I know the difference between these engines when I open the hood? (I have a 1999 Legacy L sedan 2.2, and want to be able to identify my engine as either Phase I or Phase II -- how would I know the same thing on a 2.5 Outback engine ?).
Oil in spark plug wells (1999 / 2.2) <---cause ??
corsair replied to corsair's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid I mention that the spark plug holes go through the valve covers. I looked in my Subaru factory supplement manual, and Subaru calls this defective part the "spark plug pipe gasket" The local Subaru stealership wants $195. to do both sides.
I have a 1999 Legacy L sedan with 2.2 engine. I just changed the spark plugs at 80,000 miles and find oil in the spark plug wells when I pull out the spark plug boot. The problem is worse on the passenger (right) side of the engine where the oil was almost 1 inch deep around the spark plug (starting at the spark plug gasket). There must be a gasket or seal of some kind which is defective. Anyone know the cause of this, and what can be done to stop this oil leak ?? This problem was not evident when I changed the spark plugs for the first time at about 40,000 miles. I have an extended warranty plan which will pay for the repair if I can isolate the cause & the dealership will back me up on this as being a serious problem which can only get worse.
corsair replied to rumlow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX======================================================== I checked with a Subaru stealership who says that there is a sensor INSIDE the speedo head which receives impulses from the VSS (I have a 1999). This (the speedo head) is likely the problem rather than the cluster itself. Putting the OLD speedo head into another cluster will likely not solve the problem. What needs to be replaced is the speedo head. I have an ODBII scanner and can tell you that this speedo problem does NOT set an error code into memory (since I have read no error codes on my car). If you go to a stealership, they will charge you an arm & leg to replace the speedo head and will recalibrate the speedo accordingly. I don't have an exploded diagram of the speedo cluster & head. Can you post a picture (JPG) of the back of your junkyard cluster with the head separated from the cluster?? Does the speedo head have any electronics or any electronic connections to the cluster??? If someone has a PDF with an exploded view of the cluster, can you post it for the rest of us ??? I have looked high and low for a paper manual for my 99 Legacy, but have only been able to get an update manual (about 2.5'' thick of looseleaf pages) but which has no diagrams of the instrument cluster.
Best AT filter brand for '98 OBW
corsair replied to timn29's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe replacement spin-on trans filter (if you have the spin-on filter on the left side) is a Hastings TF-170 which has the anti-drainback and wire mesh bypass valve in the center of the filter (replacing the Subaru part number 38325AA032 and 38325KA000). Also check here: http://catalog.hastingsfilters.com/ or here: http://www.wixfilters.com/filterlookup/index.asp
corsair replied to rumlow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I called Subaru on this issue and they say that there is no recall, in spite of the fact that many people seem to have this problem. How much were you charged to have the speedo head replaced (probably not under factory warranty). Doesn't the whole instrument cluster have to be removed? How long did the job actually take (if you know) ?
corsair replied to rumlow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a 1999 Subary Legacy 4dr. sedan 2.2 with the intermittent speedo problem. It seems to work more frequently than not, but I have seen that when I reset the trip odometer to zero and hold the button down, that the speedo will STOP, and then later at some random time start working. As for the pictures that have been posted here, I can see exactly on my car (passenger side) where the speed sensor would appear above the right side CV boot, BUT the sensor is not located there on my 2.2 lit. engine. Can someone tell me whether these pictures are from a 2.5 lit. Outback? The speedo speed sensor location might different on the 2.2 engine. I have seen previous posts on this same issue in alt.autos.subaru, but I have not yet seen a solution. There are no NHTSA Recalls either (yet): http://www.nhtsa.dot.gov/cars/problems/
