Esky
About Esky
  • Birthday 11/17/1981
Contact Methods
  • Website URL
    http://members.austarmetro.com.au/~pwade/
  • Location
    Australia
  • Interests
    Cars, Rallying, Computer Games
  • Occupation
    Pizza Delivery
Esky's Achievements
Newbie
Newbie (1/11)
10
  1. Cheers for all the info! Firstly, the car's a carby fed, 5 speed manual. Rear LSD sounds good, and I'll probably pick one up and do the rear disc brake conversion at the same time. Does the RX have different gear ratios as well as the diff ratio?? Also, how difficult would it be to install the centre diff into my car (if I could locate one), and would it be worth it? At current I just drive it in FWD unless it pisses with rain or I hit the dirt - this is fine, except it tends to lift the inside wheel when cornering (which should be cured as soon as I invest some money in suspension...)
  2. Just got an '85 GL 4WD Sedan, and have two questions: 1. Do all RX Turbo models come with a rear LSD? I'm assuming the LSD will simply bolt onto my propshaft.... 2. I've heard that later model L series were full time 4WD. Is this true? If so, is it simply a different transfer case, or some form of viscous coupling? Cheers, -Esky
