mod5csi
Posts posted by mod5csi
Update:
Looks like the #3 injector was just clogged. I ran some Sea Foam through full tank of gas today and it got better over time. Also replaced the fuel filter to see if that helped.
Never did figure out how to check the codes, but the CEL is intermittent now, usually off throttle coming to a stop and at idle.
thank you all for the replies
There is a noticable difference when pulling plugs 1, 2, and 4. Meaning, the idle speed does change and it runs even more rough.
Another new development on the rough idle.
It runs rough only at idle and part/throttle (cruising throttle). But it does it at any speed and any RPM and in all gears (didnt try 1st or gear) I noticed it on my test drive this afternoon. So I tested it a 30mph, 45, and 55. I tested what gears I could without overreving the motor.
Now the car sat for several months over the summer, 3-4 months. Could I have a leaky/bad/clogged/what have you injector? Im leaning toward an injector issue... at least until I can figure out how the CEL codes work and how to check them.
ok guys, help me out, please?
I am looking at the 92 FSM for the trouble shooting CEL codes. Will this be the same for 91? And, where are these connectors they are refering too, for D-check and U-check and what not. Or is there a DIY'ers way to check codes?
well...some good news I think...
I disconnected the battery this morning. And when I came home reconnected it, and now I have a check engine light! So, that will help a bunch. Just need to figure out how to check the codes
I was hoping the front oil leak might be easy. We shall see, hopefully this weekend.
Now that you mention the rear main seal, I did notice oil caked around the starter area.
I still havent crawled under the car to see whats going on there.
As for the spark...I think all 4 are getting spark now. Judging by the looks of the new plugs after 40 miles or so. But, I still get no change in engine sound/rpm when I pull the plug wire off of number 3.
I was able to get my timing light working correctly on the wires (battery terminals were corroded). And the timing at idle with no load seems to fluctuate between 12 and 20 degrees.
I hear a lot of people recommend OEM wires, not sure if thats what I have on it though. They are red wires with Yazuka or something stamped on them, they are also each stamped 1, 2, 3, or 4 respectevly. Also they have printed on them 1991 (hopefully not the original wires???)
Ok, I found a download for a 1992 Factory Service manual. Thank you to the hosts of http://www.mail.experiencetherave.com - /subaru_manual_scans/1992_FSM_(Engine_&_Electrical)/ .
Question is, how close are the '91 cars to the '92 FSM?
Hello all,
I just aquired my uncle's '91 Legacy Wagon. It is a RHD model (he's a rural mail carrier). It's a 2.2 automatic AWD, with 119,000 miles. He bought it with 100,000 miles on it from a dealership, so no previous owner or maintenance history is available. But the whole vehicle, aside from being very dusty is in pretty good condition.
Heres my dilema, I know about Hondas and Datsuns. Not much about Subarus except what is common knowledge. Ive read through the FAQ here and found a couple of helpful sites. But I thought I would ask some direct questions about the issues I am having. I do not have a Hayne's, Chilton's or FSM yet. But will get one in the near future.
1. rough idle
I beleive the number 3 cylinder is not firing at all. It seems to be getting spark, I can see and hear the spark, when I pull the wire out of the plug when the car is idling. However there is no change in engine behavior. I pulled the spark plug (champion plug) and replaced the plug with an NGK (I have replaced all the plugs with NGKs). However, the champion plug I pulled looked like it had never fired before, looked brand spanking new, gap was correct. I hooked up a standard timing light to each wire, and every wire flashed randomly, I'm assuming that is something to do with the nature of coilpacks?
2. oil leak
The main reason my uncle decided to get rid of the car is it has develepoed a noticable oil leak. It seems to drip from the front cover area, the drops on the cardboard I put under it are in a nice row, right under the front cover. There is old caked oil on the block under the alternator also. It is also dripping oil somewhere on the exhaust manifold, I am thinking it is near the collector/catalytic converter. Because the oil is dripping on the manifold, it is smoking and stinking something awful. The leak/leaks dont seem to be too bad, he parked it for 4 months when he noticed the oil leak, and it has only been driven 40 miles back to my house, with no notciable loss in oil on the dipstick.
3. hard shift into 2nd gear
Just a minor annoyance, it shifts very hard into 2nd. Im guessing it just needs a fluid change.
Anyway, sorry for the long first post, but I thought I would throw all that out and see if you guys could help me out.
Thanks for being here.
new Subaru owner, with questions
Posted
OB99W, dude you rock! Thanks I will surely be bookmarking the endwrench site!
