rusty89wagon
  1. I'm fairly new to the denver area and have discovered that whoever installed the driverside cv axle in this car before i bought it didn't put the washer on the hub, between the bolt and that conical split ring spacer centering thing, so it started makeing some noise a week and ahalf ago but i did't have time to pull it apart and check it out until tonight. I discovered that the hub was quite loose from the axle stub so i took it apart. I discovered that the aforementioned washer was missing and that the nut hade gone conical on the inside and the spacer centering thing had gone conical on the outside allowing a buch of slack between the axle and hub that had eaten up the splines on the axle and the hub. The heat of course also killed the wheel bearings and had somewhat melted the dustboot on the brake caliper. so what i need is a salvage yard that will have a subaru. or many subarus would be better. mine is a 1989 gl 4wd wagon with the fuel injected ea82 and five speed dual range. I dont know what other years and configurations use the same hub ( i planned to just take it with me to the yard). Anybody in the denver area that has suggestions for a good yard around here please help and let me know. Thanks.
