adventuroussoul
Posts posted by adventuroussoul
What does your temp guage say? Does your heater blower work at all? On high? In my 92 loyale, the blower works weather the car is warm or ice cold. There is no temp. relay controlling the blower. Maybe someone put one in thinking it would improve heating. If your car is not heatin up, check your thermostat. If your blower motor doesn't work, it might be a fuse or the resistor block that provides slow blower speeds. I think it is behind the glove box(?) Search up heater blower resistor, you should find something.
I say replace your thermostat to start with. Its real easy.
The thermostat is new but not o.e.m, I will look up the resistor.The blower has always worked just fine until now,its weird.Could I have aproblem with the heater core.
My 92 loyale wagon will not heat up and the blower will not kick on until the car has been running for 15-20 minutes.When it finally does it is just cold air,any thoughts or advice would be mucho obliged!
92 loyale engine temperature issue
Posted
My temp gauge has started reading higher than normal usually it is maybe a about a quarter of the way up,the last week or so it has been up over halfway,at first I thought it was just the extremely hot days but even with the temp dropping off it still reads high the fan is running and the oil/coolant levels are good and the motor doesnt feel really hot,any suggestions on what to check.
Thanks
