NCDIY
Posts posted by NCDIY
I helped a friend with this recently. If you know anything about electronics and take the clock apart, you'll see two square pads on the circuit board with nothing between them. The missing part is a fuse/resistor which drops the 13.8V from the car to 5V for the clock. Sometimes it burns out completely and your clock goes dead. My friend replaced it with a resistor and got his clock back. I'll see if he has a value for the resistor he used.
How do you remove the clock module? I see no screws, or plastic caps covering mounting holes, and cannot tell where [nor how hard] to press on housing sides to release catches/detents. And did your clock "fix" hold for any reasonable length of time, or is this something one has to do every year or so?
Forester high beam problem
Posted
Anyone have any ideas about this 2004 Forester high beam problem? When the
lever is moved to the temporary high beam position, the highs come on as they should for as long as I hold the lever, but when I try to move the lever to have them stay on, they don't come on [the lows remain on]. I'm guessing the switch needs replacing. Is that a DIY job? Can the switch be repaired instead of replacing it?
Thanks
