wayward3
Everything posted by wayward3
  1. Alright I got the tires to slip with no luck. Still stuck. Where is the level on the side of the tranny. Is it something I can get to from under the hood? I need to first get it out of 4WD drive first then look into it more this weekend when I have time to bypass the solinoid. Where is this "lever" and is it as easy as turning a switch. Thanks everyone
  2. Thanks for the suggestions. Tread depth is a little more wore on the front. Tire pressure is the same on all. Wheels and tires are all the same sized. Unit is a manual transmission. Should I rotate the tires?
  3. I was reading some of the posts here about rewiring the speakers. They said that since my Soob has no rear speakers that I probably do not have to rewire the speakers. As for the 4X4 I have tried driving back and forth with it the button disengaged with no luck. I don't know if the the stereo and the 4X4 problems are related but it sure is a conincidence. I just don't know why I could put in 4X4 but not get it out.
  4. My 91 Loyale is stuck in 4WD. The 4WD dash light is illuminated and 4X4 is engaged and will not come out. I recently installed a new CD player with some complication. I burnt out the horn fuse which seems to be the seatbelt fuse too. I wondering is this is an electrical problem and/or what fuse I should be looking for?? Please help
