I have a 2003 Baja.  My driveway is about a mile long and very rocky.  The underside takes a beating.
I took the car in to a Subaru dealer a month ago to get the steering aligned(4 wheel alignment).  They said the right rear links(forward & rear) were bent and would need to be replaced before attempting to align the car. I knew they had been hit by a rock or two and were dinged but they looked fine to me. I relented and $300 later I'm handed an alignment report that says the car is still out of alignment.
They are now saying:
1.) the left front strut needs replaced  because they can't adjust out the -0.5 of camber.
2.) both rear trailing arm links need replaced because they can't adjust out -1.8 left and -2.6 degrees of camber on the respective rear wheels.
My questions are,
can a strut that is not leaking, looks perfectly good, cause the -0.6 degrees of camber?  wouldn't that be the spring?
If the trailing arm links are bent, wouldn't that require all the attaching hardware to also be bent? Seems like they are just replacing parts until the problem magically goes away?
I have a Haynes manual that says I can adjust the camber in the rear wheels, but the dealer mechanic says its fixed and not adjustable? Who's right?
Scott
