rwbsage
  1. Welcome to the Soob world....check out this post http://www.ultimatesubaru.org/forum/showthread.php?t=32721 Also by doing searches you'll find sooo much great info ...
  2. Thought I might try this company's stuff... http://www.scratchpolish.com/glass_restoration.htm So can the rollers be adjusted so they don't cause the marks ? thanks Probably will have a auto glass place take a look too but I'm sure they'd cost a bit more than I'd want to spend...
  3. Hey all, My 87 RX has power window roller marks on the glass, do you think some stuff made to remove scratches from window glass would work? Is this a common problem with the older Subs with power windows ? Now if I wanted to replace the door glass what other models would work or is it just the 3 dr RXs ? thanks
  4. thanks hadn't read that one yet...
  5. Hey all, Intially when I got the RX the check engine light was on but the thing ran fine, so since it wasn't going to see heavy use let it go...Well, last week a local shop would check the trouble code for free(I tried once but never figured the code out) and found that it was code 22(knock sensor) and they fixed it (the wire was cut so they crimped it back together) No more check engine light... What was strange was it ran like crap for like 15 miles afterward, then suddenly was back to normal...Light still off....Since the weather was spring like here decided it was time to install the better carpet I had got for it....Got the old out and was going to run it to the dump but when I started the car the check engine light was back... Again I am attempting to decipher the code and it's either 2 long blinks + one short or maybe 2 long and a very quick 2 short but the blink after the 2 long seems to be just one which would indicate trouble code 21, water temp sensor....I think I found it , (near the knock sensor correct?) Do the wires pop off? And if so what do I use to get the connector off? Or is it just one unit ? As you can tell I'm not a super mechanic but I'm trying to learn.. Any help would be appreciated...I have done a search and have found a few items that relate ... The car isn't overheating and temp guage stays steady in the normal range.... thanks
  6. Any progress on the tail light and passenger seat (just need a good cover , not the whole seat) also could use misc interior screws etc...let me know...thanks So what year RX is it?
  7. cjt, should have asked about the passenger seat also....If the tailight(good conditiion) is complete with no cracks etc(a pic maybe) PT me a price....thanks...
  8. My white 87 RX - Ice ( because its cool and gets used mostly during the winter months) rwbsage
  9. Hey... I have a 87 RX 3 dr and am wondering about your RXs drivers seat condition and rear drivers side tailight condition? Also does it have the enblem on the front grille? thanks rwbsage
