Clutch help?
I found one on google for only 64 dollars so im just goin to that! is it very hard to drop the trans on these cars?
Clutch help?
well i found a clutch kit for $120 does anyone know a place that can beat that price?
Clutch help?
Well im doing this at school so i have all the tools to resurface the flywheel and everything, i just need to no what i have to have!! i bought this car for gas mileage since my other truck which is lifted gets no gas mileage at all!!
Clutch help?
Well the reason is we are already pulling the motor out of his car so i will have it off anyways. and i got my car for only 75 dollars so i dont want to put a bunch of money in to it. were can i find a good deal on a new clutch? (cheap)
Clutch help?
alright! well my friend has a 87 subaru gl 4wd turbo and his motor is shot, would the clutch off that one work on mine?
Clutch help?
Well It dont slip in first at all and u have to push the pedal almost all the way to floor to get it to disingage. Im not sure where exactly it releases in 2nd and up... But i dont understand why does it slip in all the other gears but not 1? the gear oil also hasnt been changed for about 5 years the ex owner says, could this be a reason?
Clutch help?
I have an 86 subaru dl sedan and my clutch is slipping in 2nd and up! Do i need a new clutch or could i adjust it?
Axle question!!
Ok i have 85 subaru dl sedan. I was backing up my driveway and turned and the cv joint broke. I am wondering if i will need to replace the axle or just the cv joint. The end of the axle has like a weird looking gear on it and it is just sitting in the cv joint and spining,so what do i need? ill take pics tonight
1986 subaru dl hatchback Water in oil!! help!
Well it has a timing belt! I bought the car and the lady said it ran when she parked it. The water pump is bad because water was leaking out the bearing in the front...:-\ it dont have a hole lot of miles dont no exact milage. but we poured water into the radaitor and it ran right out the oil pan!!
I have an 86 subaru dl and i just got it and the water pump went out so i removed and drained the oil and it was all milky and had water in it... What could cause this? could it be a head gasket or something worse?
subaru18
