84_GL
  1. installing new weber carb the old carb had two inlets and fuel lines and the weber only has one what do i do with the other gas line?
  2. thaks for the help im probably gonna order a weber just wanted to make sure i wasnt overlooking anything first
  3. the choke seems to be working properly closed when cold and open when warm, ive been debating on replacing the coil wasnt sure if that would cause that problem. Could the ignition also cause this its not starting good anymore either not sure if its the starter or ignition was planning on taking the starter in to have it checked. Also if i spray starting fluid on the base of the carbuator the idle pickes up ive put new gaskets on replaced the spacer and doubled up the gaskets and it still pickes up idle when i spray it not sure if the manifold or the base of the carb is warped.
  4. Hi need some help, my 84 gl wont idle warm and if i step on the gas it wants to die, ive rebuilt the carb twice, two different rebuilt kits both had some parts that were right and some that were not, ive replaced vacuum lines and nothing seems to fix the problem. Thinking of ordering a weber, wanted some advice before buying one is there anything else i should check? thanks
