jerryc38
  1. Same old question that's been asked a million times. I need air suspension parts. 1988 gl10 turbo wagon (part # on passenger side rear strut 21081 ga250) This is the only strut that is shot. Not only is the bladder leaking the shock has blown its seal. If anyone has a new drier for the air compressor I need that to. I've just remove all the water from the lines and I'd like to keep them clean and dry. Any help would be appreciated. thanks. Jerry
  2. I may be mistaken but I believe the holes are tapered and you must be careful that you drive the pin out in the right direction. If you examine the holes that are 180 degrees apart you'll notice a difference. Also be sure you align the holes properly when you install the pin. I experienced this on my son's wagon when I was changing the rear inner and outer wheel bearing assembly and had to remove the axle. I caught it but it was more luck than skill.
