evilsqwerl
  1. Sorry it took so long to get back to you guys, but i changed the t-stat out on sat and then i snapped the t-stat cover. I couldnt get a new cover till today. My car drives like a true snow warrior with no over heating:banana: Thanks guys
  2. Maybe it was just low on coolant mixed with a failing thermostat cuz it stopped drinkin it... stopped bubbleing. and my heater has never worked so good. goin for a test drive to see what happens
  3. Thanks turbone ill go check it out and let you know. It is drinkin just a little bit of coolant too
  4. While driving, it takes forever for it to warm up also. I think ill start with the rad, pull it out check its flow. I really hope its not the HG its freakin cold outside.
  5. Okay so bear with me.. Most of the work i do on cars is with rotarys. The problem started last night.. the outside temps have been about 10 degrees. So it takes my car forever to warm up and then it overheats after about 10 or so miles. There are no visible leaks. But the radiator with the cap off bubbles a little bit. From my understanding thats a blown head gasket right? There is no water in the oil. It also made a hissing/gurgling from the turbo side. Any and all help would be greatly appreciated. Thanks, Jon Oh also when I turn it off, it wont start right back up. Takes about 5 min.
  6. The one on the tps i think, not sure if it was the butterfly one. It just opened up the throttle a little, I dont know if it was adjusted by someone else but i had no choice.
  7. i just adjusted the screw and it idles fine now. i bought the 850 one but got it for 650
  8. so i checked the ecu and it showed up code 31 which is the throttle position sensor. Correct? so that shouldbe the problem right?
  9. Thanks i will look into it and let you know what i find out.
  10. So i am new to the forum and i just bought this car. I hope that this isnt a repeat thread but, so the car idles fine when its cold and then as soon as it warms up 75% of the time when stopping at a stop sign or light it wont idle and dies. I dont know if it matters but it doesnt have a muffler on it. I also just gave it a tune up new plugs, wires, cap,rotor etc... Any help would be great thanks guys.
