GRobbieT
Everything posted by GRobbieT
  1. I'll check the cam sprockets when she gets home I know the pasenger side sprockets turn with minimal effort is it okay to turn the driver side sprockets I moved them a little to line them back up but don't want to damage the valves. Oh and I meant to say WATER PUMP not oil pump it dowsn't show any tell tell signs of failure but could that be causing the problem cause the timing belt drives it? Maybe its binding the belt? It spins but maybe there's too much drag. Thanks for your responses. Do you really think a new NAPA part would cause the same problem as the original? Where do you buy a genuine subaru tensioner. wish I knew about this site when i was trying to get the crank pulley off and didn't know the starter trick, my impact wouldn't get it.
  2. New to forum heard this was the best place to go. The car is a subaru legacy outback w/ 2.5 DOHC engine about 150,000 miles girlfriend bought the car used about 40,000 ago first problem shes had and it giving me a RASH! I am having serious issues with timing belt keeps slipping a few teeth. I have replaced from start to now still having problems put puts at lower rpms while driving and slips a few teeth in the timing. I have started w/ plugs and wires then replaced crank and cam sensor (both new) then replaced w/ new timing belt. Still had issues realigned timing belt belt slipped a few teeth again. Replaced timing belt tensioner new from napa. still have issues. bearings seem good on cam idler pulleys ( I think). could it be a failing oil pump? I am sick of going in there and not fixing problem any insight as to what could be causing this slip in timing belt. Running out of patience but still willing to address problem
