vtsuby
  1. U Folks at USMB are AWESOME! Thank You! "Cougar" "seatern" & "NVExplorer" for all of your Ideas, HELP & Replies! The ECU was the culprit! A diode was rolling around in the original when i took it out you could hear it! I tried soldering it back in, but that didn't work...still no light on the ECU! I had a spare in the back yard from an 89GL, pulled the ignition relay & comp(ECU) from it and put both in the car, Check Engine light immediately came on! put the original ignition relay back in...! Lights,noCodes,ACTION! The ECU flashes the 5 short times, just like my good 94loyale... With no stored Codes! Turned the Key! Old SUBARU Loyale fired Right UP!!! SUPER! Little Chilly Today! It is only about 30 degrees in VT. (Warm for Alaska!!!!) & the car was outside! So I was very happy to have a Quick Fix! I Knew she would run again!!!! Gracious! Danke! Thanks!
  2. Subaru Loyale with the HILL HUGGER Clutch system!??? Is it a standard transmission?? I have had some real issues with the brakes on loyales! the problem seems to be in this system! Usually disconnecting it and spinning the arm that the cable connects around fully while you bleed the brakes, this should get rid of the air bubble that is trapped in this unit! One of my friends removed it, and used an "automatic trans" brake splitter in that spot... This permantly got rid of the "spongy" brake symtoms!!! Hope this helps! vtsuby!
  3. 1992 Loyale No LCD Light on ECU Computer No Spark, checked the timing belts, both seem good! -- the rotor still turns! When u turn the key, Car turns over but there is only the charge light & Brake fluid light! (no oil light or Check engine light) went and looked at the LCD on ECU computer and there is NO light flashing on the computer at all??? checked all the fuses... Cleaned the grounds, then noticed the lights missing on startup!??? My good 94 loyale has all four lights on startup, (oil, charge, brake Chk Engine) also the computer flashes 5 times quick with no problems...(check engine light is off) What next? Check for power to computer? what wire is it? any ideaS??? Thanks in advance! vt suby
