fateo66
  1. I will have to post pics, they are all completely different styles. But perhaps I'm overlooking something.
  2. Well I wasn't able to log on last weekend so here is a few updates I'm in the midst of everything and there is going to be several things to overcome. The first one is on the front hub/control arm assembly. The SVX's hubs have a small ball mount and the WRX's are a larger style. Is there any way to put a small style ball in the WRX's control arm? Then I was thinking about having the ball joint machined down but I do not believe that will work either. So it looks like now I will just be ordering a set of hubs from a 05+ STI and using the rest of the stuff off the SVX
  3. Well the SVX donor car will be here Sunday morning.....
  4. Well part of the reason I wanted to go with an SVX setup is because of the longer control arms. I would like to widen my stance to better suit my widebody.
  5. how about the SVX suspension?
  6. Awesome, I'm looking forward to tommorow unless you want to meet up tonight and I can't belive I never heard of this site before.
  7. Hi, I was just referred to come over here by Matt Monson because of some of my off the wall ideas. Anyways I have an 02 WRX and I just picked up some coilovers for a 05 STI. Now to my knowledge all rear strut mounts are the same from 02-07 WRX and STI ( I know they inverted the strut in 05 but it still bolts in the same) As for the front the hub's bolt holes I hear are a bit off. So I wanted to know what some of my options would be. Is it possible to swap in a 05+ STi front hub but keep my 5x100? But if I can I would rather go with my previous plan. Which is to swap out from the axles out from a SVX into my 02. I know that my ABS will no longer work and that the control arms are also longer but will I be able to get everything to align and possible use the STI coilovers? Here is a few pics of my latest projects
