Everything posted by fateo66
can you rebuild subaru clutch LSDs
TTTT for any more info....
New to the fourms had a front hub question
- New to the fourms had a front hub question
I will have to post pics, they are all completely different styles. But perhaps I'm overlooking something.- New to the fourms had a front hub question
Well I wasn't able to log on last weekend so here is a few updates I'm in the midst of everything and there is going to be several things to overcome. The first one is on the front hub/control arm assembly. The SVX's hubs have a small ball mount and the WRX's are a larger style. Is there any way to put a small style ball in the WRX's control arm? Then I was thinking about having the ball joint machined down but I do not believe that will work either. So it looks like now I will just be ordering a set of hubs from a 05+ STI and using the rest of the stuff off the SVX- New to the fourms had a front hub question
Why yes it is!- New to the fourms had a front hub question
Well the SVX donor car will be here Sunday morning.....- New to the fourms had a front hub question
Well part of the reason I wanted to go with an SVX setup is because of the longer control arms. I would like to widen my stance to better suit my widebody.- New to the fourms had a front hub question
how about the SVX suspension?- New to the fourms had a front hub question
Awesome, I'm looking forward to tommorow unless you want to meet up tonight and I can't belive I never heard of this site before.- New to the fourms had a front hub question
Hi, I was just referred to come over here by Matt Monson because of some of my off the wall ideas. Anyways I have an 02 WRX and I just picked up some coilovers for a 05 STI. Now to my knowledge all rear strut mounts are the same from 02-07 WRX and STI ( I know they inverted the strut in 05 but it still bolts in the same) As for the front the hub's bolt holes I hear are a bit off. So I wanted to know what some of my options would be. Is it possible to swap in a 05+ STi front hub but keep my 5x100? But if I can I would rather go with my previous plan. Which is to swap out from the axles out from a SVX into my 02. I know that my ABS will no longer work and that the control arms are also longer but will I be able to get everything to align and possible use the STI coilovers? Here is a few pics of my latest projects - New to the fourms had a front hub question
