dakos
  1. hi, could the P0446 generate a missfire on all 4 cylinders ? as the weather got cold the car runs really bad and the missfire codes for all 4 cylinders came up beside the p0466 code. the whole summer and fall the car was running fine even the code was there but now since the temperatures are dropping below - C the car runs bad... thanks a lot.
  2. hi i've got on ebay a camber kit adjustment bolts , instaled them on my rear wheels as i've got a 18' set of rims but i'm unable to get a proper negative camber, positve i can really see the diference whwn turning the bolts, but negative doesn't seems to go to much over the standard position....any suggestions? is there anything related to the struts mounting?? thanks a lot1
  3. hi, i've got this error code but the car still drives well...do i really need to fix it right away? what's the influence on long term?? thanks!
  4. hi, i'm getting same issues but i can't locate the canister and solenoid...i just got the 2000 forester which is a little bit different as engine components locations than my 99 forester...any help will be more than appreciated, pictures or a diagram. thanks a lot!
  5. well.... in Eu you can get all cars models available on diesel or gas , depends on your purposes you can buy same car with a diesel engine or gas , no further i was reading a week ago that Jaguar is offering too a TD engine regarding pollution... as far as i know the cleanest engine still is a mercedes td engine... competitions and endurance...Audi is winning the 24h at Le Mans for a few good years usind TDi engines... i do understand as much as i can the 60's muscle cars but...we are almost 50 years later and technology has really gone beyond the point where you need a 5L V8 engine to generate 500HP ... the 2L STi engine from Subaru is just a small example...
  6. yeah..sure ..i'd like to see any of the new subarus turbo models doing same mileage as the the TD engine models )) don't know about US but here in Canada diesel is still cheaper than gas... in my opinion the car industry is still controlled by the big petroleum company owners...:cool:
  7. here are some specs for the imprezza td SUBARU IMPREZA 2.0D TECHNICAL SPECIFICATION ENGINE Configuration Horizontally opposed four cylinder, mounted longitudually Construction Aluminium alloy cylinder block and heads Valves per cylinder/camshafts 4/DOHC per bank Engine capacity cm3 1,998 Bore x stroke mm 86 x 86 Compression ratio 16.3:1 Maximum power PS (bhp) @ rpm 150 (148) @ 3,600 Maximum torque Nm (lb.ft) @ rpm 350 (258) @ 1800-2400 Fuel type Diesel Intake system Variable-geometry tubocharger and intercooler Fuel supply Common-rail direct-injection Emissions control Oxidation catalytic converters, particulate filter and closed loop exhaust gas recirculation Emissions level EU4 DRIVETRAIN Clutch Dry single plate diaphragm Transmission 6-speed manual, dual mass flywheel Gear ratios/ mph per 1000rpm 1st 3.454 / 5.4 2nd 1.750 / 10.6 3rd 1.062 / 17.5 4th 0.785 / 23.7 5th 0.634 / 29.3 6th 0.557 / 33.4 Reverse 3.636 Final drive ratio 3.900 Driven wheels Full-time AWD, centre differential with viscous coupling CHASSIS Suspension Front MacPherson strut-type, coil spring, L-shaped transverse link strut, anti-roll bar Rear Multi-link, double wishbones, coil spring, anti-roll bar Steering Rack and pinion, electric power assistance Braking system Front and rear discs, ventilated at front; 4-channel ABS and EBD Stability control system Vehicle Dynamics Control Wheel size 17 x 7JJ alloy Tyre size 205/50 R17 WEIGHTS & DIMENSIONS Overall length mm 4415 Overall width mm 1740 Overall height mm 1470 Wheelbase mm 2620 Track front mm 1495 Track rear mm 1500 Front overhang mm 965 Rear overhang mm 830 Ground clearance 150 Gross vehicle weight kg 1920 Luggage capacity VDA litres Seats up 301 Seats down 1216 Kerb weight kg 1455 Payload 465 Max. trailer weight braked kg 1600 Max. trailer weight unbraked kg 650 Max. nose weight kg 75 Fuel tank capacity litres (gals) 64 (14) Turning circle kerb to kerb m 10.6 PERFORMANCE Fuel consumption mpg (l/100km) Urban cycle 40.4 (7.0) Extra urban cycle 54.3 (5.2) Combined cycle 47.9 (5.9) CO2 emissions g/km 155 Maximum speed mph 127 Acceleration 0-62 mph secs 9.0 INSURANCE GROUPS RC: 11E/24E RX: 11E/25E SERVICE INTERVALS 12,000 miles WARRANTY 3 years/ 60,000 miles, 12 years anti-corrosion cover and 3 years paintwork; 3 years membership of Subaru Assistance
  8. i came back from EU and i had the surprise the see on the road already Subaru cars with turbodiesel engines.... http://www.boxerdiesel.com/ will we get it here in the next 5 years ?!!??
  9. i guess you are right...could be the gear box on the 92 that make's run faster alt lower rpms... regarding the tire size am still on the factory specs 205/55/16... how interchangeable are the parts between old models and new ones?? can i do a full swap between the 92 and 97? i'll get the turbo engine like that on my 97 gt )
  10. i want it a little bit faster and also i don't like raving the engine doing 60-70km/h in the city... for 60km/h it goes up to 2500 rpm and for 70 almost ot 3000 rpm i have also a 92 legacy turbo , manual that has a a hi ratio diff. and it doest go more than 2000 rpm for 60 km/h on the 4 speed...
  11. thanks for the replays ..looks like i'll have to wait until i'll do a full swap... will be a 92 2.2 EJT compatible to swap in my 97 legacy ? i mean a full swap engine and transmission..?
  12. hello, i was thinking to replace my 97 gt's rear differential with a 4.4 ratio one do i need tot do any other modifications or just to do the replacement?? the car in manual transmission thank you!
  13. thanks..i'll have to look then for one that reads kms/h .... i'm aware about the Ontario legislation too..actually the one in found in US was matching my mileage + about 2500 miles more....
  14. hi, my cluster (km/h- i'm in Canada) got broken and the only ones that will match the mileage are in US and are in miles.... now, if i'll replace mine whit one that counts miles, does my car will count kms or miles , what will be stored on the odometer? thanks a lot!
  15. ok...i have interchange the sparkplugs wires between cyl 1 and 3 and it looks like the problem is gone... no more missfire and i can step on the gas again without any engine hesitation ... ps the ingnition coil has the cyl nr on it and also the wires should have checked before asking thanks a lot anyways !!
