lifeson22
Everything posted by lifeson22
  1. Ericem, that is the kind of insight I really appreciate. I'll be damned if doesn't match my problem, I hope you're right!
  2. My 07 legacy began to rattle after I turned the ignition on. It's never done this, and I just had the 60k service and inspection done 2 weeks ago at the dealer, and had all tires replaced with news ones per spec. For context, the car sat in the parking lot while it snowed and rained, creating ice that was hard and slippery - but it's done so many times before. The grumble shows up BEFORE I even move the car - and it is only in 'reverse' (with brakes on and when I tap the accelerator a bit) that it makes a hell of a grinding noise. In 'Neutral' and 'Park', the noise disappears, and in 'Forward', the noise becomes much less noticeable. The noise comes mostly from the middle underside of the car, but at times some of it seemed to come from the right exhaust, although no ice was visible inside it or even underneath the car. I moved my car about in the parking lot, and can say that making turns does not produce the noise, and moving forward the grumble was only slightly noticeable if that. It was tapping the accelerator while in reverse that produced the weird and loud grinding noise. I put a 15 AMP in the FWD slot (the AWD light did come on), but to no avail. Absolutely nothing changed, and the car behaved just as described above. The car is not even middle aged, and until yesterday (before the ice) it ran great, without a hint of this rumble (and believe me, I've been paranoid about it since the first of my 55k miles). Could it be Torque Bind, even though it's still there in FWD, and even though it's there even when the car is stopped? I should note I let the car running for about ten minutes, but the problem didn't seem to improve as the car warmed up. Insight is very much appreciated.
