Popemobile
  1. Ok got it, no easy fixes. I think it got some better from 3qt change so will do that a few more times. Plus it will be at the dealer in 2 days, I'll have em read the codes. Thank you.
  2. I've heard of using GM diff. Fluid (mouse oil) added to trans. Any idea how much to add?
  3. Nope, handshake sequence several times but, after the usual 16 flashes at key on, producing just a steady A/T Temp light, no codes.
  4. Ahh, makes sense about the FWD. I tried the handshake sequence but must have done it wrong so will try again. I have to go to the dealer because there is a Recall on the Throttle Body so if I dont get to it in a few days I will have them pull the codes. Bet it will be a 24.
  5. I have read probably 20 threads on this topic and I'm STILL not all there. SO HERE GOES: 1997 Legacy Outback A/T. I think it is an early one because my timing belt tentioner is the old 2-piece style. 200K miles 16 flashes of A/T temp light on start up, wheels binding, (front and rear), at slow speeds and Trans load up which releases at stop. I tried putting fuse in FWD - no light for FWD came on and still binding and still 16 flashes If I turn the wheel all the way, then put car in neutral and shut it off the bind releases and I can push the car with no binding I bought this car recently. Prev owner had a leaking rear tire for some time from wheel corrosion. Tires are now up to spec. Just topped off trans. fluid, it was down 2.5 quarts but no burn, (like new). I need to check it again though - it was really tough getting a good read from the dipstick My plan was to keep changing 3 quarts of trans fluid each week to see if that fixes things, sound reasonable? Thank you
