Everything posted by soukka
EA82T lack of power and idling problem
It doesnt have cat. Not required in finland because the car is so old. And doesnt also have o2 sensor.
Time has passed and subie isnt still working. Compressions were 8.6:1 and for new ea82t i think they are 8.8:1. So what way could the fuel go to the crankcase?
Aah dvom, now i know. I thought that its some sort of expensive and old subaru tester Its 1988 model and it has that hotwire meter. Whats that screw on the meter? It spins and spins like the thread is gone. Btw, engine check light doesnt light up when the car is running. Gotta check on monday are the piston rings fine, i think they are gone because it smells fuel when i open the engine oil filler cap. Gotta do compression test also. Btw, how much is 0-60mph time on 1.8t leone? I think its like 10-12sec now. And finally what is that cylinder shaped thing on the hose between maf and turbo? Some sorta resonance chamber?
Okay ill test it, what is DVOM? Can i measure resistance between different the maf pins? I got autodata on my computer but it doesnt know anything, it had even firing order wrong but this forum saved me
I changed the fuel to new. Today i welded half of the floor and driver side wheel arches from inside and checked all the hoses after MAF. What is that big round cylinder shaped thing in front of right fronlamp? And what is the thing that is near driver side damper and hood hinge. CO did go lower when i removed air filter box and sprayd fine mist of water to turbo intake hose. I emptied the whole fueltank and replaced it with 70% of pure alcohol and 30% of fuel and it did go trought emission test. I think the piston rings are gone because when i open the motor oil filling tube it smells like fuel and the oils are now 10miles old Gotta take the engine off and rebuild it and put bigger turbo, megasquirt, front mount intercooler, higher compression and custom intake&exhaust manifolds It lacks much of power, my own peugeot 205 1.9turbodiesel is twice as fast to 0-160kmh
I know, forgotted to mention that the car doesnt have cat because our law doesnt force to have it because the car is so old.
Hi, My firen bought and leone with ea82t engine. Car has been in a barn for last 6 years and when i started to repair it i changed, sparkplug wires, sparkplugs, fuelfilter, airfilter, oilfilter and engine oils. Now the problem is that the car wont go trough "katsastus" (in Finland we have to take every year our cars to inspection that they are road legal) because it has too high CO in emission test. Limit is 3.5ParticlesPerMillion and now its like 8ppm And when i drive with car and accelerate on 2nd gear and rpm is like 5000 and then it just twitches and you almost break your neck, then it slows down and accelerates normally. I test drived another leone with same engine and it accelerates much faster than this one im repairing. Sorry for my bad english
