subarudan
Everything posted by subarudan
  1. Hey Josh, that worked! I got trouble code 21: "Open and closed ends of passenger's door latch switch are ON." I'm guessing this means my door latch switch is not working like it's supposed to. I'm assuming this is not the door sensor switch that you can hold in with your thumb, but a switch inside the door next to the latch? Any insight as to fixing or replacing a door latch switch? Dan
  2. Thank you very much. I didn't know that had a garage. They're so funny. Thanks!!
  3. Oh, that makes sense. Yeah. I'm at work, and I don't know how they have the firewall set up. I'll try these when I get home. Thank you very much!
  4. Thanks Josh, but the links you included don't load for me. I can't get to: http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/autoseatbeltdiag1.jpg or... http://www.main.experiencetherave.com:8080 or even... http://www.main.experiencetherave.com Do you have a copy of these stored away somewhere?
  5. If my '90 Legacy has any problems on a trip up to Boston, does anyone know of a good but cost conscious mechanic up that way??
  6. The passenger side automatic seat belt mechanism is stuck forward on my '90 Legacy. I can manually move it most of the way backwards, but when I turn the ignition, it just returns to the forward position again. I try this with the door closed, verifying on the dash that the door is in fact closed, while sitting on the passenger seat. Also, there is an LED icon of a guy with a seatbelt on the dash blinking as if to tell me something is wrong with the seatbelt. Well, yeah. I'm hoping it's a fuse or a relay or something. Has anyone had this problem? If not, what else could I check? Help?!
