SuBeast
Everything posted by SuBeast
  1. Success! :banana:I was able to get the caliper up and take the rotor off. I was hoping to be out driving it around the sand dunes today but the new rotor I purchased was slightly off so in turn the pads were wrong. I should have everything by Wednesday. Let's hope the weather is still nice! Thanks for all the info. It was a great help through this.
  2. Thank you very much. I am going to go get some Liquid Wrench and bash on it a little bit today. I also noticed that there is a required C-Clamp to push a piston in. Can you explain that a little more? I have been unable to find a diagram of the brake to see where I am to place this. It is still necessary if the brake is siezed?
  3. I have a 1987 Subaru GL 4WD. The Front Passenger Caliper will not move and is grinding metal to metal. I have tried WD40 to loosen things up but it will not budge. I am able to remove the 1 lower bolt but then the caliper will not slide up lke the manual states it should. Any hints as to how I can fix this without taking it to a mechanic?
