EA 71 / EA 81 ignition wiring diagram
Cougar, you are perfectly right Cougar! I did exactly the reverse connection... Following your information : now it is working perfectly : almost 2 cm spark turning slowly delco by hand! Just have to put back in the engine and it should start!! So here is what I did to make it work : 1) This is the Sensor/Ignition Module with 2 pins : Coil (yellow), +12v (black/white) ------ / | | |_____ | Coil ) | O ) | + _____) \ | \ | ------- I connect Coil (yellow) to Minus (-) of ignition coil I connect + of sensor (black/white) to +12v I connect + of ignition coil to +12v Its seems so easy now, but I didn't even know if a intermediate module was missing or not since I got the engine without the car So http://www.mobiletron.com.tw/detail_main.asp?ID=978 is wrong for me but http://www.nbhuaao.com/en/proview.asp?P_ID=1022 is ok In order to help people with broken ignition module (but it seems to be very strong since I made reverse connection and bad wiring, and still alive now!) Following the last url : the list of cars with such a module : GM AstraLB 1.5 1984-1986 AstraLC 1.6 1986-1987 GMTRUCKS 1982-1985 Others1.9L Eng. S10, S15 1982-1985 HONDA Accord2 1986-1987 AccordEFI 2.0 1987-1989 Prelude1.6 Coupe 1979-1982 Prelude1.8 Coupe 1983-1984 Quintet1.6 1981-1982 ISUZU OthersPick-up 2.3L (4 ZDI) Eng. 1986-1987 TrooperMKII 2.3 1986-1987 NISSAN 3101.5 (E 15 Eng.) 1981-1982 PrairieM10 1.5 1985-ON Pulsar1.5 1983-1986 Sentra1.5, 1.6 1982-1983 SunnyFWD 1.3, 1.5 (B11) 1984-1986 SUBARU BratA.T. 1984-1985 Brat Dist.NO.429878900 1985-1988 Subaru1.8L Eng. 4 W.D. 1981-1986 Subaru1.8L Eng. AT 1984-1988 A list of ignition module equivalent : 22020-15M00 22020-15M20 22020-P4005 30120-PAO-661 30120-PH0-661 30120-PH4-005 49146--7401 8942433440 94243344 2 vendors : http://www.lott.de/product_info.php/products_id/82098/ktnr/7679 And finaly an explode view of a similar (almost 100% identical to Hitachi subaru model) : http://www.hondapartsnow.com/civic/30120-PH4-005~ca13sa00~2.html (click on "component" to get the detailed view) Thanks 4x4_Welder's, thanks Cougar you can not imagine the time spent to find this information on the web! Regards from France :)
Thanks a lot! Hope the engine will start now..! I discovered pinout connections of the sensor/ignition module : but they are exactly inverted...an idea of the good one ? http://www.mobiletron.com.tw/detail_main.asp?ID=978 http://www.nbhuaao.com/en/proview.asp?P_ID=1022 It seems also that we can find the same module in Honda civic 1300 from 1980 to 1983 http://www.hondapartsnow.com/Page_Product/PartDetail.aspx?catalogID=22&productID=4&yearID=13&doorID=2&gradeID=56&areaID=3&transmissionID=3&originID=-1&colorLabelIDs=-1&colorLabelID=-1§ionID=1&idAndImageID=3844%20457257&refNo=12&isBigPicture=False&pageName=&appid=4190 And I guess in other car : Nissan but don't know which one .. GM:94243344 HITACHI:E1261 HONDA:30120-PA0-661,30120-PH4-005 32120-PA0-661 NISSAN:22020-15M00,22020-15M20 ISUZU:8-94243-344-0 LUCAS:DAJ106 SUBARU:49146-7401 Thanks a lot
Hi all, I bought a Suburu EA-71 engine in order to replace a Rotax in a ultra light airplane ( ballerit HM 1000) The ignition coil was missing, I bought one from another subaru vendor. The problem is that there is no spark at the ignition coil output. I maybe made a wrong connection but I don't find any wiring diagram. My hall sensor has to wires : yellow and Black/white. Ignition coil has to pi : + and - I have connected Sensor: sensor yellow <--> battery + sensor black&white <-> coil + coil - <---> ground = battery - I am wondering now if there is any control unit between coil and sensor.. Does anybody can help ?? Thanks a lot if any idea I will bought a repairing manual but not sure to find this diagram inside...
titikaka
