cl4yd0h
Posts posted by cl4yd0h
  1. Im totally stumped..
    I have the plugs out and can hear compression in all cylinders when i spin the crankshaft in neutral. Its connected to everything.. and the timing belt doesnt even budge.
    As far as I can tell the timing belt is directly connected to the crankshaft, correct??
    When I put the car in gear and move the crank shaft the timing belt moves?
    Am I just overlooking something stupid?
    I mean the timing belt should spin when cranking over engine with starter, or else how is the damn thing gonna start.. How the heck do the gears play a role in this???
    Its to my understanding the timing belt directly relates to the crankshaft.
    correct me if im wrong..
  2. Also a fuse under the hood in a box next to the battery. Always good to check for a broken timing belt.
    I checked all the fuses under the hood, but not the relays, I dont know how to check if those relays are good? Other then you can hear some go off when you pull them out.
    The indicators just say SBF-1 etc. I have no idea what SBF is.
    I will also check the main relay under the dash and try to find out somehow if its good or not.
    I will also check the Timing Belt and get back to you guys.
    Thanks for the help so far!
    (Sorry for double post, wacky internet.)
  3. Also a fuse under the hood in a box next to the battery. Always good to check for a broken timing belt.
  4. Hey, This is a cool place you got here, Glad I found it.
    Out of no where went to start up the car and would just turn over. Wouldn't fire or even pop off a couple times.
    Ran awesome up until then, no prior symptoms.
    From check engine light blinking ive managed to gather this information:
    33: Vehicle Speed Sensor Circuit
    11: Crank Angle Sensor or Circuit
    13: Cam Position Sensor or Circuit
    31: Throttle Position Sensor or Circuit
    Light was never on before this happened, it all happened at once when i tried to start.
    I Checked any fuses that correlate with anything important and I couldnt find any blown ones, even checked alot of em for continuity.
    Checked for spark with timing light and couldnt get anything out of all 4 cylinders.
    Checked the coil pack connector for voltage and couldnt really get any readings that made sense.. like .6 or .8 volts..
    Im a Chevy truck guy, I really dont know how these ignition systems or coil packs really even work..
    But I would assume its not firing because it doesnt know when to because of loss of readings on sensors. Is there a common wire or fuse for these sensors?
    These Boxer engines are a whole new world for me.
    Any help or suggestions would be awesome..
    I lose my job if I cant get this dang thing to run. So thank you in advance, Im really in a pickle here!
    EDIT:
    Also replaced alternator 1000~ miles ago
