espressoforyou
Everything posted by espressoforyou
  1. Everything was going great and then I noticed that the CV stub came out when replacing the passenger side axle. I have a couple of questions: 1. Should I have been able to pull the stub out of the transmission? I would have thought that the circle clip would have prevented the axle stub form coming out. The clip did not come off of the stub. 2. Can I just reinsert the stub and will the clip compress as it is going in? Note: I but everything back together by just pushing the stub and CV axle back in. Do I need to worry that the clip will not hold the the stub in? Thanks for your help.
  2. I have 2003 Baja. It has started running hot when the AC is on and the Baja is not moving. It does not run hot every time I stop, just a couple time a week. It will run hot after idling for a few minutes. I have checked and both cooling fans are working. When it run hot I start driving and with-in 1/4 miles the temp returns back to normal. Any suggestion to what could be wrong?
