So I finally got around to diagnosing my 87 GL 10 with an EA82T today.
It's been parked since last fall when it started running on 3 cylinders, so I did the usual litany of tests:
Spark all around
Compression is good all around
Timing belt didn't jump a tooth
The problem SEEMS to be a bad injector on number 3.
But over the course of my switching the injectors between cylinders on the rail I noticed the plastic nose cones (nozzles?) were cracked. Well, one is actually missing a chunk!
The seals that seat over the plastic cones seem to be fine...
Since this is an indirect injection motor do these need to be replaced?
Seems like a vacuum leak would be the worst problem this could cause, is that assumption correct?
Thanks- PHIL
