kansas
  1. No, I don't think I have any bubbling in the coolant resevoir. I've checked the container after driving 20+ miles. The substance does look and feel like oil to me in the coolant. Is there another problem I should suspect other than head gasket?
  2. Hi, Legacy Wagon 1995. I had my head surfaces resurfaced, my head gaskets and o-rings, cam seals, rear separator plate and oil filter replaced last fall. The symptom at the time was oil in my coolant. Currently I have driven my car long and short distances, and you would not be able to tell anything is wrong with it. It does not overheat and drives like a charm. But I still have substantial oil in my coolant resevoir and radiator. I do not have coolant in my oil. I have had the coolant system flushed three times. Now I have to decide whether or not to let the dealer brake down the motor again to see if the head gasket work was not done properly. If the work or parts were shotty - they pay. If it is not the head gaskets - I pay, big. I want my parts warranty if it is the head gaskets, just not sure if I can gamble with the big bill if is not the head gaskets. So far I have had two separate dealers do pressure test and hyrdocarbon tests and both tests come back negative. Help, why else could there be oil in my coolant.
