fuel tank willl not take fuel
ron98 replied to ron98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhere is the vent soleniod? all the lines leave the charcole canister and go over the frame for the rear end. I tried lowing it a few inches but that wasn't enough to see or feel where they go. Do I have to pull the tank? what does it look like? thanks ron
ron98 replied to ron98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen i bought the car it had over 3/4 of a tank. I put some seafoam in it and drove it down to under a 1/4. This was over a week or so. The day before i tried to fill it the check engine light came on. It was p1443 which i think was evap vent solenoid. I clear the code and it has not come back. But i rarely drive it. Until i figure it out. Thanks ron
ron98 replied to ron98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPulling nozzle out a little doesnot help. Do i have cel. I donn't know what your asking. Thanks ron
I have a 1998 impreza that i just purchased. It had sat for a year and a half. When i try to put fuel in it the pump keeps shutting off. It shut off every 20 to 30 cents. I have traced the breather to the charcoal can. From there it goes over the frame that hold the rear end.i would appreciate any idea. Ron
No spark
ron98 replied to aberti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThankyou. It was the ignitor. It runs on all cylinders but seem to have a rattle in the lower end. I have not change oil since i purchased it. I was trying to get it running right first. Do subaru motors have lower end noises. Thanks ron
No spark
ron98 replied to aberti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. I was wrong. Both 1&2 do not have spark. I have been told igniter is in ciol . Is this correct or what and where is it? The injectors have juice. The car starts and runs, just on two cylinders 3&4. Could it be the computer? Thanks ron
No spark
ron98 replied to aberti's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi, i have a 98 impreza i just puchased. It doesn't have spark on #1 cylinder. I tried replacing the coil with the same result no spark. The coil was used but i was told it was good. Any ideas? Ron
ron98
