Hey guys as you can see I am new.
Well I have a 99 Impreza L 2.2l SOHC Auto and it blew up with a horrible sounding crank walk slash rod knock. So i bought a EJ25(3 I believe.) SOHC out of either a 2001-2002 Subaru legacy so all the intake manifold and the connectors were different So i swapped the connectors. and also swapped the drivers side timing pulley and replaced the head gaskets and the head bolts. Since I know they have issues with HG. So now I am stalled at the issue of my car will crank and spark and has compression. It does not have fuel. The fuel stops at the FPR (fuel pressure regulator.)
My injectors when i dummy lighted them, They are not probing. also the cam shaft sensor is not showing up on the dummy light either. I know I have spark but i don't know if it is sparking enough I am running the stock EJ22E ECU and the stock wiring. I also timed it my self and it is timed perfect to what the manual said at autozone. ({Correct me if I am wrong this could be my problem.} When you time the car you time the crank shaft pointing straight up and the timing pulleys straight up with the marks in the pulleys.) Please help my I finally get my parts to put it back together and on the road and I can't (its been in my garage for 1 year with no motor!!!:mad:) Thank you for all your help Im sure this will answer some one elses question or I am just un lucky and get a lemon. lol
Tyson
