Warfrin
  1. Thank You for all the great info! Hopefully I will post a pic with the EJ22 in the unit when complete!
  2. I am in need of an exhaust header for an ej22 that is light weight. O.E.M is to heavy for my application...would really like some direction with this. thanks in advance...btw the turbo is now removed.
  3. I have the engine and a box of wires, I need a schematic to hook it up into the hoverwing, so I know like pink and red with yellow strip are for the tach...my grounds etc...
  4. Sorry if this is in the wrong thread, but it appears it is the only thread I can post into.....anyway here goes. I would like to help my friend get a new EJ-22 16 valve engine wired into his hoverwing (link to what the heck a Hoverwing is please click here for context) Below is a brief outline of the spec's for the Hoverwing Specifications UH-18SP Hovercraft UH-18SPW Hoverwing™ Capacity 6 Persons (1000 Lbs) 2 to 3 Persons (550 Lbs) Max Speed 75 mph 75 mph Hover Height 8 inches 8 inches Max Altitude N/A 10 ft Length 18 ft 10 in 23 ft 10 in Width 7 ft 6 in 20 ft 2 in Empty Weight 800 Lbs 844 Lbs Climb Gradient 33 to 40% 33 to 35% Recommended Engine 85+ EA-81, EA-82, or EJ-22 Subaru 85+ EA-81, EA-82, or EJ-22 Subaru Construction Method Foam and Plywood Composite Foam and Plywood Composite Construction Time 250 hours 275 hours I believe it will be 120 or 130 HP. If anyone has an electrical Diagram for the engine and what it needs to run (bare bones I would take it) that would be REALLY REALLY great. **Looks like there maybe some guages involved like water temp, oil pressure and all that jazz...thanks!!
  5. Yes I am So new to the Subaru..I do not even own one, but I have a lot of questions, so I look forward to hearing from you in the future!! Peace from Canada!!
