1996 Subaru Legacy Wagon Issue
gvr4737 replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope the front cat exploded and clogged up the whole exhaust fix = gutted both cats and ran a de fouler on the 02 sensor soo its legit
gvr4737 replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi used ngk spark plugs gapped correctly and oem replacement wires from advance auto... i may still have the stock set i can try if u think this could be it i put probably 200 miles on after wires before this
gvr4737 replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXso finally got it to throw a cel again.. it thru the colde p0301 and p 0302 my guess is i have a grounding issue... im gonna buy all new ground cables and re do them anyone else got an idea??? i threw my ecu back in the car for good too starts but runs poorly
gvr4737 replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXim gonna go over all my power and grounds tommorow what is the main relay i could try car starts and runs.. just like crap... and wont rev up.. like over fuels
gvr4737 replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi did get gas at a shady gas station before this happened... i checked the fuel filter and it is clean.. could the pump be clogged??? should i drain the tank and try new gas
gvr4737 replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjust did wires n plugs
gvr4737 replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy would u think skipped timing belt??? thats the only thing i didnt think about basically the car starts and idles, but when you rev it it overfuels and like bogs than dies
I have a 96 Subaru Legacy wagon. 2.2L 5 speed. Everything was running good on the car till last week when it lost power and broke down. Now the car still starts, but runs poorely. When i give it gas it just boggs and dies. also idles rough never had an issue before with this car soo i finally got the CEL to come on and here are the codes p0105 Manifold Absolute pressure circuit p0201 Injector 1 Control Circuit p0204 Injector 4 Control Circuit p0301 Cylinder 1 misfire p0136 02 Sensor Circuit Malfunction soo i figure with throwing all these codes and after checking out all these parts that it is the ecu. soo i took out the ecu. it looked and smelt fine whatever, i got a new one from a place online now my ecu is 2N 22611 AC930 the ecu that i recieved was a 2D 22611 AB414 I put the ecu in the car and it will not start at all does anyone have any idea why this is doing that??? my car is a 96, This ecu i baught was supposed to work for a 5 speed 2.2l legacy wagon 95-97 please help!!!! thanks - Mark- Ps: I also do not know for a fact its ECU but i figured it could be since it threw soo many codes
gvr4737
