Check engine codes?
Thank u very much!
Check engine codes?
anybody have a list?
Check engine codes?
I have come up with multiple codes now:mad:(33,34,35,51) and was wondering if anybody had a list of the engine codes for a 1992 loyale, i can not find a code list anywhere, Thanks for your help!
Check engine codes?
I found out it was code 34 witch is the EGR solenoid. cant find a solenoid tho:mad:
POOR oil pressure HELP!
I will go pick up a different gauge and let u know what happens
I had a bad tick yesterday so i put some seafoam in the crankcase and drove it about 5 miles and tick went away, could this have anything to do with the oil pressure?(i heard it was normal for these cars to tick)
what would i have to to remove to just replace the whole pump?
I have a 91 loyale that has about 150,000 miles on it, I have about 25-30 on gauge in morning, then when it warms up i have close to nothing sometimes, i was told by local subaru mechanic that they will be fine with hardly any oil pressure(it does run fine and never gets hot) i was wondering what i should do, I just replaced both head gaskets and water pump and just got it all back together and really dont want to tear it all down again, but if i have to i will.Thanks for any advice
Check engine codes?
i cant seem to find the led light that flashs the codes, is there anymore detail you could advise? Thanks
Check engine codes?
Thanks for the quick answers, i owe u one!
Check engine codes?
Thank you, i have heard alot of similar problems but it is always when their cars are cold,(mine is warmed up then it does it)wierd huh?
Check engine codes?
I have a 1991 loyale 1.8 and was wondering how to check for codes? My CEL turns on when it warms up and seems to be slower as soon as it turns on, any help would be awesome, Thanks
91soob
