windrupted
Everything posted by windrupted
  1. Thanks Mike! I had just done that very thing after noticing it being slightly loose and very grimy. Chopped it off, stripped the wire back to clean wire, brand new female and scraped the male "spade" on the solenoid shiny clean. Maybe thats it, but I still detect that lag in cranking.....no difference thus far as it's all warm and juiced up, I need to get up in the Rockies at -10 and let her sit by the trailhead all wet and cold for a week (on a good sized slope of course). Thats why I got the car, Awd for snow. Ironic that this starting snafu makes it the last car in the world youd want to depend on in such conditions....is there any fizzled relay I could be overlooking? Its got a rust free west coast body with good orig. white paint, a few dings, 240K and strong, solid clutch, new brake pads, perfect 5 speed trans and some jerry rig shift linkage problem that will require dropping the engine halfway out to access.....(still shifts but very sloppy) if anyone on the LA to Denver via I-70 corridor wants a challenging project. Oh, and a very moody starting scenario. I am walking away from this car at some point soon. Its also had the front end bushings done and is extremely smooth and tight at 80mph. The linkeage problem plus the 240K has got the junkyard calling me. She's too good for that but I am out of time and patience. (oh, and the 2.2 is a bit underpowered for the AWD and big 16" rims.) 500 bucks! Current Ca. reg out to next October!
  2. I just found this forum while desperately looking for what was keeping my car (95 Legacy AWD 2.2 5 speed) from cranking. It is this "crank circuit", as the starter and battery are new and the battery is getting 14.3 volts while running and all contact points have been scraped clean. When it gets the juice it turns over strongly and starts right up, (i squeezed a giant battery in there for more cranking amps.) When it wont crank theres no solenoid click, theres no noise whatsoever. Thanks for illuminating my real problem, which brings me to the real question now that I know it: Whats a crank circuit? The route from key to solenoid I imagine. I am guessing there is a bad relay or connection in it. Oh, the 1st thing I did was chop out the clutch pedal safety system and hook it up permanantly, and it seemed to solve the problem for a while. But now, it sometimes takes a few seconds to "load up" enough juice to get through, and when I press the clutch pedal down out of desperation and the prior muscle memory reaction I could swear it helps to kick it over. Yet normally theres no need to do the clutch, so perhaps it just luck that it kicks when I go for the pedal. It takes anywhere from 1 to 10 seconds for this time lapse from turn-key to start-crankin. Whew, now what?
