Got the timing belts figured out but the injectors are not delivering fuel plenty of fuel pressure nothing has changed with the execption the new engine had the inuction system on with injectors that we used they are not clicking ? Triple checked all the wires all are fine? On my way from Alaska to Mexico and am stuck in Arizona till I get it running
I have a timing belt issue I have a xt6 motor in my vw campervan the fly wheel is vw with no marks? The dist has been moved to run off the passenger side cam pully. I put the #1 piston top up and have installed the belts by the book but nothing but a few backfires. It's hard to tell if the #1 is on the compression stroke because the cams are so far off? Any ideas?
I have xt6 engine in a 1979 vw campervan my problem is the flywheel is a vw with no timing marks. How do i reinstall new belts? The dist has also been moved to run off the passenger side cam pully. Can't make it run by placing #1 top up then installing the belts to the marks on the covers ??
