antonio97b
Everything posted by antonio97b
  1. No sun roof. Also if it helps I did notice some mold on a few papers that managed to get under the board that covers the spare tire well.
  2. Back Windows steam on the inside all the time. if its below 70 or if there is a shower ill have to roll the Windows down and have heat on full blast just to try and keep it down. Long term damage is mold and mildew everywhere. I don't know where to start to find tgis issue. Upon cursory glance, the back window squeeges no longer contact the window. Is it possible that the rain rolls down the window then goes in the door which will then evaporate on the inside? Advice on where to look or start would be appreciated
  3. Now my tail lights ate working but my five aren't. I wasn't able to check out my fog light bulbs
  4. My rear tail light lamps are 2057, dual filiment. The fog lights are the middle switch on the left switch tree which turn on the the bottom amber lamps on the front. The middle top flip switch is labeled "P" which turn on the little lamps in my head light assembly. I'll check my fog lamps when i get home but I doubt that its the issue. They were both fine before they were all out
  5. One burnt out a while back but at the time i didn't drive it much so I didn't Chanel it until I noticed the last one burnt out(or so I thought, filaments wasnt burned in half but was messed up enough that I thought it was the issue). Replaced both and didn't have any back lights What is PM?
  6. All my fuses are ok. If by switch on top of the column you mean my parking light the fronts and back turn oni never noticed this actually. I can do this as a temp fix byt hopefully I can fix the issie. Thanks a million so far. It saves me from a ticket for now
  7. Just did a quick check, as I have to leave for work in an hour. Yes my trailer harness is a little melted on one end (not badly and it's just the connector not the actual wires). Also I noticed there are little nicks in the harness in the wires around my tail lights, which is really odd because no one has done wiring work on this car. I bought it from a college teacher with full service records and the only repairs it had done was a new CV. Is this normal? I did a google search for "1999 subaru impreza melted trailer harness" and found nothing. Is there a recourse guide to what happened to other owners?
  8. I have 1999 Subaru Outback. I noticed that my fog lights were both out so I checked all around the car and noticed my tail lights were out too, yet the brake filament part of the bulb still worked. so I know it's not a socket issue. My headlights are turn signal works and when I put on the fog light part of my colum switch my dash lights turn on. Does this sound like a relay issue? Are the tail lights and fog lights connected by a relay? The wiring schematic looks like it says it does but I'm not the best at reading those. If you could point me in a direction that would help me out so much. I commute 28 miles to work every morning in the dark and I'm having people constantly flash me and honk.
