99 2.2 into 01 with a 2.5
I got the header pipes from the 2.2 .. Wasn't sure if I had to swap intakes ? I was told to swap cams and cam sprockets.. Didn't know if the wiring was plug and play or not..
I was told this will work so I m ready to go just wanted someone to tell me exactly what I have to swap... I have a 2001 legacy outback with a 2.5 that got ran w/o oil so it's making a horrible knocking noise.. I got a 2.2 from a 99 impeza to go into it.. I did alot of the older swaps but this is my first on the sohc and or phase 2... Thanks
Tranny and engine interchange
ssheaven replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo PA... Does that go for both the 2.2 and 2.5..? There is a 2.2 engine from a 99 impreza mt w150,000 forsale by me cheap.. Was going to pick it up... Sure I ll find something someone smoked a motor in to put it in.. What will that motor all swap in to.. Did alot of the swap s for the 97 to 99 obw but coming into these newer ones I'm not real sure on..
ssheaven replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSweet.. With all the knowledge on here there isn't a project on Subaru I won't try... May I ask y u have to change cam sprokets?
I have two ? S and can't seem to find the answer.. I have 1995 auto trans w awd from a impreza that had a 2.2.. Sedan but no longer have the car.. Have had alot peeps wanting to know if it ll fit legacys that came w a 2.2 sedan or wagon? The second ? Is an 03 legacy obw w a 2.5 needs engine what years cross over along w 2.2 swap.. Found one from 99 impreza 2.2 will it work
Motor tranny swap 99 ob
ssheaven replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSweet thank you guys much.. There s nothing wrong w a subie that scares me to try and fix w all the knowledgable peeps on here
I have an 99 legacy ob w a 2.5.. Headgaskets were needing done when I bought it but heads r shot.. Have a 95 impreza 2.2 I put in it and worked great but I now believe the awd isn't wking.. I noticed the front tire chirped in driveway at take off so I took it up a wet grass hill.. The front tire spun then it hooked up.. Going to put on jackstands and make sure.. but my ? Now is I have the whole 95 w good working trans, transfer, and rear diff can I swap it all out to the obw.. The 95 was wreaked that's y I became the donor car.. Or what do I have to do to get awd wking
transmission leaking at rear on 5 speed
i am looking at buying a 1999 legacy gt limited with a 2.5.. it has a 5 speed in it but the lady said it is leaking at the rear seal on tranny... is it just the seal? how to check for another problem causing it to leak? common problems w these trannys? help i dont want to make a bad choice and bite off more then i can or want to chew
ej25 heating up
ssheaven replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes i did along w new head bolts also.. this is about the 5 th one i did and never had any problems w any of the othe ones so far.... it does seem 2 be going through anti freeze though could it b burning it out the exhust? the plugs all looked good when i checked them... this car did sit for about 4 months till i started working on it... did the system just get that drained down?
ej25 heating up
ssheaven replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi bleed the system cleaned radiator... ran it for about 15 miles temp was great. it was bubbling a bit in the overlow tank but not crazy... guess i ll find out if i make it to work tomorrow..lol
ej25 heating up
ssheaven replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi didnt bled the coolant and will try that.. i m flushing radiator now.. yes radiator and fans were all damaged in the hit.. i repalaced both w them out of a 97 2.2... fans are coming on thats the only thing keeping it from overheating completley.. the temp goes up fans come on temp goes down.. the heat is up and down after driving for about 10 mins.. the temp needle goes 3/4 the way up then drops to 1/2 then up then down... how can i test for a headgasket failer?
ej25 heating up
hello.. i have an 97 ej25 obw w a 154000 on it.. i did the headgaskets at about 140xxx... i hit a deer this winter after getting the front end put back together it started over heating.. pulled the top radaitor hose and water pump seemed to wking good.. did a compression test and all where between 175 and 190... the only thing diffrent is the radiator is out of a 97 ej22... spark plugs are all burning good and are autolight double plat.. is the head gasket out again?
97 obw wont start after airbags deployed
ssheaven replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat is the best way 2 fix this problem.. new valves.. are the heads bad now or cams? not sure what 2 do now?
ssheaven replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe belt never came off just got pushed behind the lower ideler pulley.. both the upper and lower cam pulleys had spring tension on them when i relased the timing belt.. do u still think this is my problem.. is there anyway 2 tell if the valves are bent w o pulling the heads
i have a 97 obw w ej25. it hit a tree this winter. both airbags came out and the tree hit dead center. put the a/c conderser and radiator into the motor.. i have a donor car to fix this one.. as i ripped all the scrape metal out i found out it crushed the timing cover and put the timing belt behind the lower pass. side pulley.. i replaced all the pulleys and put the car back into time and replaced both pass and driver side airbags... when i tried to start it up it couched and sputtered and wouldnt stay running. also the cel is flashing and a ticking noise that seems 2 corasponed w the cel light flashing coming from inside the driver side dash.. do i have 2 reset something HELP im lost
ssheaven
