Hello all,
New to the board and not sure if this is the right place. Anyhow, the problem is, I have an EA81 engine in a VW beetle. A couple months ago, I had some wiring issues in the car so I started to mess around. Initially I thought I the coil was bad so I replaced the MSD coil with an Accel coil. Turned out that this was not the problem. A wire had shaken loose. So today I go out spray some starting fluid in the carb and get it running. Took a while for it to run and it ran as it did before. The problem is that I have a really tough time getting it to start. First I thought it was a fuel problem, but it stays on when started and the fuel prssure seems to be ok. I am convinced that there is an ignition problem but I don't know where else to look. The weird thing is that each time it has started, it seemed to have fired right as I was going to turn the engine off. As I moved the key a tiny bit in the off direction. Does anyone have any ideas? I would greatly appreciate it.
