lucid_door
  1. Good for you pal, way to go +1 for repping Wisconsin too eh!
  2. Crank sensor failing when it warms up? I had a Sebring a couple years ago drive me crazy for a day with random dies-while-drivings when it was warmed up; it never once set a crank sensor code, but on one drive I finally caught it hiccup on the scope pattern before it died again.
  3. Hey good for you pal Always a good idea to dig a little and see what's out there; good luck keeping your Subarus on the road
  4. Isn't that the damn truth LOL very well written points sir I certainly do as much as I can to give customers every option available, with the pros and cons of doing or not doing certain things. I always let them decide what they want to do after educating them as much as possible; I figure it's their money, they need to decide what they want to do with it. As long as I can give them as much info as possible to make that choice, I feel ok about whatever they want to do I know for sure when my replacement motor comes up for it's next belt change at 100k I'll be tossing in all new stuff so I don't have a repeat performance of a locked up idler
  5. Why only do the job once when you can do it twice with more parts at three times the price LOL They're all filthy like that, every last one. Anyhow, I changed my belt at 200k and had an idler seize up at 217k, which wrecked the block and necessitated putting in a newer motor. I'd never do another belt without replacing the whole set of idlers, seals, tensioner, and water pump again; they're just so simple to do while you already have everything apart, and worth the peace of mind, not to mention keeping you from having to pay for the whole job again plus the parts that should have been done in the first place If you can't afford to do it right the first time, you certainly can't afford to do it twice.
  6. All I can really add to the previous post is to second getting a swivel adapter for the bellhousing/starter bolts/nuts underneath, and an 18" extension, makes life really easy underneath. And make sure instead of pulling entire harnesses, just disconnect the great big plugs between the engine and body instead, piece of cake. Take it slow when you think you have everything removed and you're beginning the lifting procedure, just in case you catch on something or maybe missed a connector or hose somewhere. It's amazing how simple these engines are to remove.
  7. I tried that many years ago to save a transmission in my 1978 Ford LTD. It lasted for 6 months, but then it lost 3rd, 2nd, and finally 1st, within 3 miles. Not so hot. I'd just figure out where the leak was and take care of it.
  8. I seem to remember reading about how water pump impellers wear out and then don't push coolant through the system. How many miles on your water pump?
  9. I remember doing ECU reprograms on tons of Buick/Olds/Pontiacs that would set an EGR code. GM determined that while installing a new valve would fix the code, their tolerances were too tight and the slightest film of buildup would cause another code to set even with the new valve. So we reprogrammed looser tolerances in for the EGR system. Same type of scenario; not really a malfunction as far as malfunctions go, just settings so strict it didn't allow for any real world usage.
  10. My '90 does the same thing; never fails, if I try to limp wrist slam it shut, it always pops back out. I never gave it any thought, it's been doing that forever
  11. My timing belt idler pullies made it to 217k miles before one of them seized up and tightened the bolt holding it on into the block so hard it tore a chunk the size of a gobstopper out of the block......... obviously no helicoiling that one back in LOL wrecked the block because of one little pulley. Definitely a must to replace them, speaking from experience.
  12. Hah yeah that was a different thread LOL http://www.ultimatesubaru.org/forum/showthread.php?t=111302 And thanks for the input, I haven't been able to find anything definitive on here about trans computer compatibility.
  13. So I just replaced the AWD auto trans in my 90 Legacy with a used unit, and I am noticing it has the same soft, slightly hesitant 2-3 upshift and 4-3 downshift the old transmission had, exactly how it behaved when I first got it with the original trans, 3 years later and 3rd gear goes out completely (the reason I had to get a different trans). It's just such an unsure shift compared to the snappy 1-2 and 3-4 shift. Not really wanting to burn up another transmission, I'm wondering if this is how they all shift, or would it be some common problem affecting both transmissions? Do the TCM's in these cars go out frequently, where it would cause the shifts into 3rd to be so soft? And if I do try a module, should I get one to match the year of the trans, or the year of the car (tranny is from a 94 wagon, mine is a 90 wagon)?
  14. nipper makes a good point about engine specific oils. I hit 170k with my old 3.1 Corsica years ago with conventional, never burned a drop the entire time and it ran like a top when I finally sold it. I've been sold on synthetic for years now though. I had a Corolla with the 3 speed auto, and that thing would hit 4000 rpm on the interstate, and I ran Mobil 1 5-40 (the Delvac stuff they came out with for the Duramax when the 15-40 conventional proved to be too thick up here in Wisconsin winters LOL) in that vehicle for the 5+ years I owned that; really good oil, and it wouldn't burn off nearly as fast as any other oil I tried. I had to run conventional in my Trooper as well, as it had the classic Trooper head gasket leak; got rid of that with 140k on the clock. My Legacy's first engine hit 217k on MaxLife synthetic before one of the timing belt idlers seized and tore a big chunk out of the block; I always wonder how long it would have gone had that not happened. Speaking of vehicle specific, I can't wait until GM's new synthetic requirement comes out and I have to explain to the drivers of these vehicles why their oil change is going to cost 65$ minimum to keep their warranty. Hard enough getting the VW/Audi crowd to believe their owner's manual when I let them know what they should be using LOL
