NWFanatic
Posts posted by NWFanatic
this Brighton doesn't have a tach but the motor sounds like it's over revving when cold and also the RPM don't seem to drop off fast enough when you let off on the gas to shift gears. I located a used instrument cluster w/tach. Can I retrofit it and have a working tach?
my 00 Brighton with only 61,000 miles has a problem that just cropped up. The engine runs at a high RPM when 1st started(esp when cold) and RPM's don't drop when you 'blip' the throttle. When you put a load on the engine RPM's drop. Does anyone know what the problem might be?
2000 Legacy Brighton wagon w/5 spd-engine runs @ high RPM when 1st started
Posted
thanks for the advise esp on the tach retrofit. The problem turned out to be a TB sensor. One other question-is there a way to lubricate a squeaky cluthc pedal?
