yuflesh
  1. Im just replacing the prop that came with it. I havent purchased the new prop just yet. Old one has a crack and damage on it. Currently there is 66" on it, but I think I can fit 72 ", which will lower it to about 3200 rpm without too much noise. If you got suggestions for a prop, im all ears. Still very much in looking stage... Thank you
  2. weber carb came with motor. Can you / is it worth converting to FI? Sounds like either of them will work for power band..... smaller prop will use more fuel....but probably not significant difference. Thanks
  3. hi everyone, new to the group, just bought a hovercraft with ea82, subaru 1.8l motor. Need to replace the prop on the hovercraft. Where is the powerband on this motor? I got an option of 66 " prop which runs best at 3600-3800 rpm, or 72" prop that will run best at 3100 - 3200 rpm. Which one will produce more torque / hp in the above rpm ranges. Thank you Marko
