ErnestoII
  1. I fixed the driver's window on my '00 OBW. The bolts fell out and the third one was loose. I got everything aligned and tried it to see if it would work properly. I got it right - so I put everything back together.
  2. I took the door panel off on the OBW. I found 2 bolts that were in the plastic covering. I played around with the switch and finally got the regulator aligned to the bolt holes. I tried the window several times before I put everything back together.
  3. My driver's door window would not go up very far this morning. It made a crunching noise. I had to get out of the car and pull the window up while pulling on the window switch. I would appreciate any help. The car is a '00 OBW.
  4. My driver's door window would not go up very far this morning. It made a crunching noise. I had to get out of the car and pull the window up while pulling on the window switch. I would appreciate any help.
