apesofdoom
Everything posted by apesofdoom
  1. I went to http://1stsubaruparts.com/ and came up with the part number 12033AA210 found some NPR rings at https://www.carpartsdiscount.com/piston-ring-engine-set.html?3593=62163 now it doesn't say what size these are but I would bet that they are 1.2mm 1.5mm and 3mm rings and so far I ave not seen anything that says that the rings in the turbo are different then the ones in the naturally aspirated EJ22
  2. I got EngineTech S96904 from rockauto.com http://www.rockauto.com/en/catalog/subaru,1992,legacy,2.2l+h4+turbocharged,1269592,engine,piston+ring,5640?a=Ad+Code+G-autoparts
  3. Hello I need a little help. I'm working on rebuilding my EJ22t that come out of a 1992 Legacy. When I was putting on my new piston rings I noticed my compression ring was really loose. So I pulled out my calipers and measured my old rings. Turns out my oil scraper ring and my compression ring were the same thickness, so I'm assuming I need to get a set a rings that are 1.5mm 1.5mm 3mm. so I went online and all I been able to find are 1.2mm 1.5mm (3mm or 2.8mm) and the set that I all ready have is 1.2mm 1.5mm and 3mm, at this point I'm starting to feel like I'm going crazy. If you guys need pictures of anything just let me know and i will post them up. Thank you
