Dfreeman321
  1. i will help off road on dirt will put power to the out side wheel instead of the in side
  2. all i know is it is a lmted slip and it was a flood car 03 h-6 with no trac control and its not and open diff i just want the lmted slip to get side ways on dirt, and they both are auto trans
  3. i have a 98 outback and i got a 03 h-6 rear locking diff how do i change the ring to my diff or wuts a good way to make this work
  4. it seemed to run better with the batt disconnected for a few then 10feet later dyed out no power 3 misfire and the noid light test seemed to be ok all the patterns where the same
  5. but if the ex valve dont open then that could be it, but with 180 in 1 and 3 ill check 2 and 4
  6. me too i had the ex down and the valves looked OK ill try that in the am thanks so maybe ecm or bad injector wire? but with one bad injector the car should still run, it doesn't want to run at all
  7. #1 and #3 were both at 180 psi, i did have a unexpected high idle code that hasn't come back it ran good for a few and has slowly ************ out now i cant drive it
  8. i have tried it all wires plugs injectors compression check moved wires plugs and injectors but nothing has helped got a solid cyl3 misfire runs like crap need help tried it all
  9. hey i have a 07 legacy out back how can i lift it and where can i find parts
