gar52hpny
Everything posted by gar52hpny
  1. I WAS TOLD AFTER REMOVING THE NEGATIVE BATTERY TERMINAL TO CLEAR THE EMISSIONS COMPUTER YOU NEED TO DRIVE THE CAR A NUMBER OF MILES. CAN SOMEONE LET ME KNOW THE NUMBER OF MILES THAT I NEED TO DRIVE TO RESET THE EMISSIONS COMPUTER THAT WILL ALLOW THE NYS EMISSIONS INSPECTION TO BE COMPLETED SUCESSFULLY. THANK YOU, GARY
  2. WHAT PARTS WHERE REPLACED WHEN THE BELT WAS REPLACED: 1. AUTOMATIC BELT TENSIONER 2. WATER PUMP 3. BEARINGS 4. TIMING ADJUSTMENT
  3. MILEAGE: 160K TUNEUP: 120K TIMING BELT CHANGED: 120K, 140K the belt self adjust part jammed, belt broke, valves jammed, had valve job done at subaru dealer.
  4. CHECK ENGINE CODES FROM AUTO ZONE: 1. P0301 2. P0302 3. P0303 4. P0304 5. P0420 6. P0172 7. P0106 8. P1137 I look forward to hearing from you. Gerry
  5. Hello, My warning light goes on and off intermently. I am looking for solutions to resolve.
  6. Hello, can anyone provide advice with adding subaru or other transmission additives. Outback 2002 2.5, 110,000k miles. Nothing wrong with transmission but thinking it may help with shifting and longevity. Thank you, gary
  7. I recently replaced the radiator cap and the thermastat with genuine Subaru parts from the dealer. Thank you, Gary
  8. 2002 outback 2.5, when the car heats up, then overheats the cooling fluid overflows into the coolant overflow tank and does not flow back into the radiator. When I pour the coolant from the overflow tank back into the radiator I can drive for a short distance then the engine overheats and the coolant overflows back into the overflow tank.
  9. Hi, Does the thermastat need to be placed in a certain position to work properly. Just not what is the top and bottom but also a certain position for the air trap? Thank you, Gary
  10. How does air/bubbles get in to the cooling system? Thank you, Gary
  11. Hi, Can anyone provide me with tips how to bleed the air from the cooling system? Thank you... Gary
  12. Nipper, Thank you for your reply. Just to make sure that I am reading this right you are saying that this 95 Forester and my 2002 outback motor have the same timing belt installation instructions? Also, what web site has the best Subaru origional equipment prices for these parts? Thank you, Gary
  13. Hello does anyone have timing belt replacement instructions with pictorials for an 2002 outback wagon 2.5 engine type: Ej251axbwl, model:bh9cy4r, vin:4s3bh665527641758 automatic. Also, in addition to the timing belt, what other parts should be changed? Thank you, gary
  14. Hello, has anyone experienced the tube between radiator and overflow leaking and sucking air into the cooling system? Thank you... Gary
  15. Hi. Does anyone have any knowledge and or experience with DIMPLE OIL, TRANSMISSION or DIFFERENTIAL magnet plugs? WEB SITE: http://drainplugmagnets.com/subaru.php Thank you... Gary
  16. Can anyone let me know where I can get the wiper transmission linkage and wiper arm for a 2002 subaru Outback Wagon 2.5., OEM and Reman on line. Thank you, Gary
  17. I just started the 2002 outback 2.5 with a cold engine and cold coolant, almost immediately I heard a click and the cooling fans started for about 10 seconds then turned off. That happened several times before I turned the engine off. I had heard the click previously but the short cycle seems to be new. Does anyone have any ideas what that means? Thank you... Gary
  18. External, does not have oil that floats in the radiator or overflow after sitting overnight, the oil on the dip stick is normal color, feel and smell with no discoloration or signs of coolant or water. Can not see where the coolant is leaking yet...any suggestions where to look? It is progressively leaking more. I live in Hyde Park, New York between Albany and New York City...Any help would be appreciated. Thank you again. Gary
  19. I have a 2002 Subaru Outback 2.5, 109k miles. I was wondering if I should replace them with that many miles or is their a practical non equipment tests that I could perform myself to guage them? Thank you... Gary
  20. I have a HG leak....2002 OUTBACK 2.5 Does anyone have opinions on H.G. Sealant repair fixes and what product you would recommend? Thank you.... GARY
