Kitewoman
  1. Thanks for the help Everyone, The mechanic seems to think battery too. Will report back when we've got it confirmed but it's in for tests now. Thank you to everyone for all your input. What a friendly group, thanks!
  2. Hi there, I have a 2000 Legacy Outback wagon with 140K gentle miles. Everything has been working relatively well. I've been noticing an occasional "hot" smell sometimes when I stop the car but the fluids are all fine and the temp needle is always where it normally is. This may have nothing to do with the issue. The hot smell seems like coolant, not oil, not electrical. But all fluids seem at good levels and no indications otherwise of any problems but I mention it because it is new. But here is the strange electrical issue: I did some short errands, approx 10 miles, parked the car as usual, in park, lights out. Returned, put the key in and turned the two clicks, at the instant of the second click all went dead. Everything. No dome lights, no radio, no emergency flashers nothing. Complete lack of electrical power. Also could not budge the automatic shifter. (I wanted to put the car in neutral push it to a slightly better location) After trying some various things, the door opening finally got the dome lights to come on and the door open indicator on the dashboard lighting up too. Key could be inserted and clicked once without loosing the lights, but going to the second click killed everything again. Radio is dead but CD changer goes thru it's power-down routine which it never does in regular use. More strangeness: When the door is open, dome lights and dash lights are on then if I step on the brake pedal it kills all the lights/power again. I have to close the door, then re-open to get some lights/power back. I cannot get any power to start the engine at all, the key clicked into the second click kills all power to the vehicle, but opening the door brings back the interior lights. No headlights of any description. Did not try the fog lamps. Other doors opening will also bring on the interior lights, but not the tailgate. Open that all stays dark. Pushing the emergency flasher button gets a clicking sound but no flashing lights. It was dark when this all happened and I was close to home. So I did not investigate further. Key does look worn. Someone suggested it may be worn out. I did not have the spare with me and it was too dark to fuss with the emergency key I have on the car. I've had batteries go out before but this is not like that. When I can get the lights on, they are good and strong. The key and the brake pedal can kill the power to the lights however. Very strange. I thought I'd ask here to see if anyone had any ideas. Thanks for your help!
